Datasheet STMicroelectronics ISM330DHCX — Даташит
Производитель | STMicroelectronics |
Серия | ISM330DHCX |
iNEMO inertial module with Machine Learning Core, Finite State Machine with digital output for industrial applications.
Купить ISM330DHCX на РадиоЛоцман.Цены — от 240 до 1 068 ₽ SMD | |||
ISM330DHCX STMicroelectronics | 240 ₽ | ||
ISM330DHCX STMicroelectronics | 1 068 ₽ |
The ISM330DHCX is a system-in-package featuring a high-performance 3D digital accelerometer and 3D digital gyroscope tailored for Industry 4.0 applications.
ST’s family of MEMS sensor modules leverages the robust and mature manufacturing processes already used for the production of micromachined accelerometers and gyroscopes.
The various sensing elements are manufactured using specialized micromachining processes, while the IC interfaces are developed using CMOS technology that allows the design of a dedicated circuit which is trimmed to better match the characteristics of the sensing element.
In the ISM330DHCX the sensing elements of the accelerometer and of the gyroscope are implemented on the same silicon die, thus guaranteeing superior stability and robustness.
The ISM330DHCX has a full-scale acceleration range of ±2/±4/±8/±16 g and a wide angular rate range of ±125/±250/±500/±1000/±2000/±4000 dps that enable its usage in a broad range of applications.
All the design aspects and the calibration of the ISM330DHCX have been optimized to reach superior accuracy, stability, extremely low noise and full data synchronization.
An unmatched set of embedded features (Machine Learning Core, programmable FSM, FIFO, sensor hub, event decoding and interrupts) are enablers for implementing smart and complex sensor nodes which deliver high performance at very low power.
The ISM330DHCX is available in a 14-lead plastic land grid array (LGA) package.
ISM330DHCXTR | |
ISM330DHCXTR | |
N | 1 |
Корпус | VFLGA2.5X3X.86 14L P.5 L.475X.25 |
- MEMS and Sensors > iNEMO-Inertial Modules
