Datasheet Texas Instruments TMP6131DYAT — Даташит
Серия | TMP61 |
Модель | TMP6131DYAT |
±1% tolerance 10kΩ linear thermistor available in 0402 and 0603 package options 2-SOT-5X3 -40 to 125
TMP61 ±1% 10-kΩ Linear Thermistor With 0402 and 0603 Package Options datasheet
PDF, 1.7 Мб, Версия: E, Файл опубликован: 14 фев 2020
Купить TMP6131DYAT на РадиоЛоцман.Цены — от 34 до 1 116 ₽ 9 предложений от 5 поставщиков Терморезистор: THERMISTOR | |||
TMP6131DYAT Texas Instruments | 34 ₽ | ||
TMP6131DYAT Texas Instruments | 35 ₽ | ||
TMP6131DYAT Texas Instruments | от 96 ₽ | ||
TMP6131DYAT | 1 116 ₽ |
Pin | 2 |
Package Type | DYA |
Industry STD Term | SOT-5X3 |
JEDEC Code | R-PSSO-G |
Package QTY | 250 |
Carrier | SMALL T&R |
Маркировка | 1GK |
Width (мм) | 1.2 |
Length (мм) | 0.8 |
Thickness (мм) | 0.6 |
Max Height (мм) | 0.65 |
Mechanical Data | Скачать |
Approx. price | 0.05 | 1ku US$ |
Interface | Resistance |
Operating temperature range | -40 to 125,-40 to 150 C |
Package Group | SOT-5X3|2,TO-92|2,X1SON|2 |
Package size: mm2:W x L | 2SOT-5X3: 1 mm2: 1.2 x .8 (SOT-5X3|2),2TO-92: 6 mm2: 1.52 x 4 (TO-92|2),2X1SON: 1 mm2: .6 x 1 (X1SON|2) PKG |
Rating | Catalog |
Resistance (25°C) | 10000 Ω |
Resistance tolerance | 1 % |
Sensor gain | 6400 ppm/°C mV/Deg C |
Supply current(Max) | 400 uA |
Vin(Max) | 5.5 В |
Бессвинцовая технология (Pb Free) | Да |
- Evaluation boards: TMP6EVM
Linear silicon TMP6 thermistor evaluation module
- Methods to Calibrate Temperature Monitoring SystemsPDF, 144 Кб, Файл опубликован: 10 дек 2018
- Methods to Reduce Thermistor Linearization Error Memory and Power RequirementsPDF, 286 Кб, Файл опубликован: 13 дек 2018
Mostthermistorsare highlynon-linearovera wideoperatingtemperaturerange.In manycasesthermistorlinearizationovera widetemperaturerangeprovesto be a challenge.For examplein someautomotiveapplicationsthe operatingtemperaturecan varyfrom–40°C to 150°C. Linearizationin this rangeis notwithoutsignificantsystemtradeoffs.Thisultimatel - Using Thermistors to Optimize the Thermal Performance of IGBT ModulesPDF, 212 Кб, Файл опубликован: 15 авг 2019
- Using Thermistors to Enhance Thermal Protection for Battery Management SystemsPDF, 121 Кб, Файл опубликован: 15 авг 2019
- Measurement error caused by self-heating in NTC and PTC thermistorsPDF, 296 Кб, Файл опубликован: 14 июн 2019
- Self Diagnostics and Environmental Sensing in IP Network CamerasPDF, 344 Кб, Файл опубликован: 10 окт 2019
- How to monitor board temperaturePDF, 1.6 Мб, Файл опубликован: 28 янв 2019
- Temperature sensing fundamentalsPDF, 64 Кб, Файл опубликован: 28 янв 2019
- High-Performance Processor Die Temperature Monitoring (Rev. A)PDF, 357 Кб, Версия: A, Файл опубликован: 17 окт 2019
Серия: TMP61 (5)
- TMP6131DECR TMP6131DECT TMP6131DYAR TMP6131DYAT TMP6131LPGM
- Semiconductors > Analog and Mixed-Signal > Sensors > Temperature sensors > Thermistors
