Datasheet Texas Instruments OPA855-Q1 — Даташит
Серия | OPA855-Q1 |
Automotive 8-GHz gain bandwidth, decompensated transimpedance amplifier with bipolar input
Datasheet
Купить OPA855 на РадиоЛоцман.Цены — от 108 до 30 213 ₽ 26 предложений от 12 поставщиков Модуль оценочный для OPA855 в корпусе DSG (8-pin WSON) | |||
OPA855IDSGR OPA2330AIDRBR OPA2320AIDRGR OPA2316IDRGR OPA2314AIDRBR OPA2172IDRGR OPA211AIDRGR OPA1678IDRGR, | 108 ₽ | ||
OPA855IDSGR Texas Instruments | 419 ₽ | ||
OPA855IDSGR Texas Instruments | 428 ₽ | ||
OPA855DSGEVM Texas Instruments | от 15 477 ₽ |
OPA855Q1DSGR | |
Статус продукта | Анонсирован |
OPA855Q1DSGR | |
N | 1 |
Pin | 8 |
Package Type | DSG |
Industry STD Term | WSON |
JEDEC Code | S-PDSO-N |
Package QTY | 3000 |
Carrier | LARGE T&R |
Маркировка | 855Q |
Width (мм) | 2 |
Length (мм) | 2 |
Thickness (мм) | 0.75 |
Pitch (мм) | 0.5 |
Max Height (мм) | 0.8 |
Mechanical Data | Скачать |
Parameters / Models | OPA855Q1DSGR |
2nd harmonic, dBc | 80 |
3rd harmonic, dBc | 86 |
@ MHz | 10 |
Acl, min spec gain, V/V | 7 |
Архитектура | Voltage FB |
BW @ Acl, МГц | 2500 |
CMRR(Min), дБ | 90 |
CMRR(Typ), дБ | 100 |
Основные особенности | Shutdown,Decompensated |
GBW(Typ), МГц | 8000 |
Input bias current(Max), pA | 18500000 |
Iq per channel(Typ), мА | 19.5 |
Number of channels | 1 |
Offset drift(Typ), uV/C | 1.25 |
Operating temperature range, C | -40 to 125 |
Output current(Typ), мА | 80 |
Package Group | WSON|8 |
Package size: mm2:W x L, PKG | 8WSON: 4 mm2: 2 x 2 (WSON|8) |
Rail-to-rail | No |
Rating | Automotive |
Slew rate, V/us | 2750 |
Slew rate(Typ), V/us | 2750 |
Total supply voltage(Max), +5V=5, +/-5V=10 | 5.25 |
Total supply voltage(Min), +5V=5, +/-5V=10 | 3.3 |
Vn at 1 kHz(Typ), нВ/rtГц | 1.9 |
Vn at flatband(Typ), нВ/rtГц | 0.98 |
Vos (offset voltage @ 25 C)(Max), мВ | 2.5 |
OPA855Q1DSGR | |
Бессвинцовая технология (Pb Free) | Да |
Серия: OPA855-Q1 (1)
- Semiconductors > Analog and Mixed-Signal > Amplifiers > Operational amplifiers (op amps) > High-speed op amps (GBW>=50MHz)
