Datasheet Texas Instruments OPA991 — Даташит
Серия | OPA991 |
40-V, single 4.5MHz, rail-to-rail input/output, low-offset-voltage, low-noise op amp
Datasheet
Купить OPA991 на РадиоЛоцман.Цены — от 75 до 3 583 ₽ 14 предложений от 8 поставщиков 40-V, single 4.5MHz, rail-to-rail input/output, low-offset-voltage, low-noise op amp | |||
OPA991TIDCKR Texas Instruments | 75 ₽ | ||
OPA991TIDCKR Texas Instruments | 77 ₽ | ||
OPA991SIDBVR Texas Instruments | 84 ₽ | ||
OPA991IDBVR | 3 583 ₽ |
OPA991IDBVR | OPA991IDCKR | OPA991SIDBVR | |
Статус продукта | В производстве | В производстве | В производстве |
Доступность образцов у производителя | Нет | Нет | Нет |
N | 1 | 2 | 3 |
Pin | 5 | 5 | 6 |
Package Type | DBV | DCK | DBV |
Industry STD Term | SOT-23 | SOT-SC70 | SOT-23 |
JEDEC Code | R-PDSO-G | R-PDSO-G | R-PDSO-G |
Package QTY | 3000 | 3000 | 3000 |
Carrier | LARGE T&R | LARGE T&R | LARGE T&R |
Маркировка | O91V | 1HB | O91S |
Width (мм) | 1.6 | 1.25 | 1.6 |
Length (мм) | 2.9 | 2 | 2.9 |
Thickness (мм) | 1.2 | 0.9 | 1.2 |
Pitch (мм) | 0.95 | 0.65 | 0.95 |
Max Height (мм) | 1.45 | 1.1 | 1.45 |
Parameters / Models | OPA991IDBVR | OPA991IDCKR | OPA991SIDBVR |
Approx. price, US$ | .384 | 1ku | .384 | 1ku | .384 | 1ku |
Архитектура | CMOS | CMOS | CMOS |
CMRR(Min), дБ | 109 | 109 | 109 |
CMRR(Typ), дБ | 130 | 130 | 130 |
Основные особенности | EMI Hardened,High Cload Drive,MUX Friendly,Shutdown,Small Size | EMI Hardened,High Cload Drive,MUX Friendly,Shutdown,Small Size | EMI Hardened,High Cload Drive,MUX Friendly,Shutdown,Small Size |
GBW(Typ), МГц | 4.5 | 4.5 | 4.5 |
Input bias current(Typ), pA | 10 | 10 | 10 |
Input common mode headroom (to negative supply)(Typ), В | -0.1 | -0.1 | -0.1 |
Input common mode headroom (to positive supply)(Typ), В | 0.1 | 0.1 | 0.1 |
Iq per channel(Max), мА | 0.685 | 0.685 | 0.685 |
Iq per channel(Typ), мА | 0.56 | 0.56 | 0.56 |
Number of channels | 1 | 1 | 1 |
Offset drift(Typ), uV/C | 0.3 | 0.3 | 0.3 |
Operating temperature range, C | -40 to 125 | -40 to 125 | -40 to 125 |
Output current(Typ), мА | 75 | 75 | 75 |
Output swing headroom (to negative supply)(Typ), В | 0.025 | 0.025 | 0.025 |
Output swing headroom (to positive supply)(Typ), В | -0.025 | -0.025 | -0.025 |
Package Group | SC70|5,SOT-23|5,SOT-23|6 | SC70|5,SOT-23|5,SOT-23|6 | SC70|5,SOT-23|5,SOT-23|6 |
Package size: mm2:W x L, PKG | 5SC70: 4 mm2: 2.1 x 2 (SC70|5),5SOT-23: 5 mm2: 1.6 x 2.9 (SOT-23|5),6SOT-23: 5 mm2: 1.6 x 2.9 (SOT-23|6) | 5SC70: 4 mm2: 2.1 x 2 (SC70|5),5SOT-23: 5 mm2: 1.6 x 2.9 (SOT-23|5),6SOT-23: 5 mm2: 1.6 x 2.9 (SOT-23|6) | 5SC70: 4 mm2: 2.1 x 2 (SC70|5),5SOT-23: 5 mm2: 1.6 x 2.9 (SOT-23|5),6SOT-23: 5 mm2: 1.6 x 2.9 (SOT-23|6) |
Rail-to-rail | In,Out | In,Out | In,Out |
Rating | Catalog | Catalog | Catalog |
Slew rate(Typ), V/us | 21 | 21 | 21 |
Total supply voltage(Max), +5V=5, +/-5V=10 | 40 | 40 | 40 |
Total supply voltage(Min), +5V=5, +/-5V=10 | 2.7 | 2.7 | 2.7 |
Vn at 1 kHz(Typ), нВ/rtГц | 10.8 | 10.8 | 10.8 |
Vos (offset voltage @ 25 C)(Max), мВ | 0.75 | 0.75 | 0.75 |
Бессвинцовая технология (Pb Free) | Да | Да | Да |
Серия: OPA991 (3)
- Semiconductors > Analog and Mixed-Signal > Amplifiers > Operational amplifiers (op amps) > General-purpose op amps
