Datasheet G2R-1 12DC - Omron Даташит Реле,, PCB, SPCO, 12 В DC — Даташит
Наименование модели: G2R-1 12DC
Купить G2R-1 12DC на РадиоЛоцман.Цены — от 46 до 5 785 ₽ 24 предложений от 17 поставщиков реле: 12В, 530мВт, 10А, UDC: 30В, G2R-1-DC12, TRI-12VDC-SB-1CL-H | |||
G2R112DC Omron | 46 ₽ | ||
G2R112DC Omron | 106 ₽ | ||
G2R112DC Omron | 177 ₽ | ||
G2R112DC Omron | 178 ₽ |
Производитель: Omron
Описание: Реле, PCB, SPCO, 12 В DC
Power PCB Relay
G2R
· Creepage distance of 8.0 mm (0.31) min.
between coil and contact. · Dual-winding latching type available. · Plug-in and quick-connect terminals available (see G2R-S(S) data sheet). · High sensitivity (360 mW) and high capacity (16 A) types available. · Highly stable magnetic circuit for latching endurance and excellent resistance to vibration and shock. · Safety-oriented design assuring high surge resistance: 10,000 V min. between coil and contacts. · UL, CSA approved, marked with CE.
Ordering Information
To order: Select the part number and add the desired coil voltage rating (e.g., G2R-14-DC12).
- Тип реле: Power
- Nom Coil Voltage DC: 12 В
- Contact Current Max: 10 А
- Contact Voltage AC Nom: 250 В
- Contact Voltage DC Nom: 30 В
- Coil Resistance: 275 Ом
- Contact Configuration: SPCO
- Coil Type: DC Coil, Monostable
- Coil Current: 43.6 мА
- Nom Operating Power: 530 мВт
- Relay Mounting: PC Board
- Внешняя длина / высота: 29 мм
- Внешняя ширина: 13 мм
- External Depth: 25.5 мм
- Max Contact Current AC: 10 А
- Max Contact Current DC: 10 А
- Max Contact Voltage AC: 240 В
- Max Contact Voltage DC: 30 В
- Max Operating Temperature: 70°C
- Min Temperature Operating: -40°C
- Mounting Type: PCB
- No. of Poles: 1
- Series: G2R
- Approval Bodies: CSA, SEMKO, SEV
- Approval Category: UL Recognised
- Coil Operating Lower Percent Limit: 70%
- Coil Operating Upper Percent Limit: 110%
- DC Coil Power: 530 мВт
- Max Switch Current: 10 А
- Operating Time: 15 мс
- Release Time: 15 мс
G2R1 12DC, G2R 1 12DC
