Datasheet DILM80(110V50HZ,120V60HZ) - Moeller Даташит CONTACTOR, 3 POLE, 37KW — Даташит
Наименование модели: DILM80(110V50HZ,120V60HZ)
Купить DILM80(110V50HZ на РадиоЛоцман.Цены — от 29 052 до 46 300 ₽ | |||
DILM80(110V50HZ,120V60HZ) | 29 052 ₽ | ||
239399 DILM80(110V50HZ,120V60HZ) Eaton | 46 300 ₽ |
Производитель: Moeller
Описание: CONTACTOR, 3 POLE, 37KW
Type: DILM80(110V50HZ,120V60HZ) Article No.: 239399 Sales text Contactor,37kW/400V,AC operated
Ordering information Connection technique Description Description Rated operational current AC-3 380 V 400 V Max.
rating for three-phase motors, 50 60 Hz AC-3 220 V 230 V AC-3 380 V 400 V AC-3 660 V 690 V AC-4 220 V 230 V AC-4 380 V 400 V AC-4 660 V 690 V Conventional free air thermal current I th = I e AC-1 at 60 °C Open Can be combined with auxiliary contact Actuating voltage Contact sequence Ith = Ie A 130 DILM150-XHI(V).. DILM1000-XHI(V).. 110 V 50 Hz, 120 V 60 Hz P P P P P P kW kW kW kW kW kW 25 37 63 11.5 19 26 Ie A 80 Screw terminals 3 pole Springloaded terminals on the auxiliary and control circuit terminals
Notes concerning the product group
1
Accessories 1 Overload relay 2 Suppressor 3 Auxiliary contact module Further actuating voltages Accessories 278442 281199 277376 277379 281227
- Тип реле: Contactor
- Contact Configuration: 3 N/O
- Внешняя длина / высота: 170 мм
- Внешняя ширина: 90 мм
- External Depth: 176 мм
- Max Contact Current AC: 80 А
- Max Contact Voltage AC: 400 В
- Mounting Type: DIN Rail / Panel
- No. of Poles: 3
- Approval Bodies: IEC/EN 60947, VDE 0660, UL, CSA
- Dielectric Voltage Coil to Contact: 440 В AC
- Dielectric Voltage Contact to Contact: 440 В AC
- IP Rating: 00
- Insulation Voltage: 690 В AC
- Max Coil Voltage: 120 В AC
- Max Main Contact Current AC3: 80 А
- Power Rating: 37kW
DILM80(110V50HZ120V60HZ), DILM80(110V50HZ 120V60HZ)
