Datasheet DILM9-01(230V50HZ,240V60HZ) - Moeller Даташит CONTACTOR, 4KW, WITH 1NC AUX — Даташит
Наименование модели: DILM9-01(230V50HZ,240V60HZ)
Купить DILM9-01(230V50HZ на РадиоЛоцман.Цены — от 6 599 до 385 208 ₽ Контактор: 3-полюсный; NO x3; Вспомогательные контакты: NC; 9А | |||
DILM9-01-EA(230V50HZ,240V60HZ) Eaton | от 6 599 ₽ | ||
DILM901(230V50HZ.240V60HZ) | 385 208 ₽ |
Производитель: Moeller
Описание: CONTACTOR, 4KW, WITH 1NC AUX
Type: DILM9-01(230V50HZ,240V60HZ) Article No.: 276725
Ordering information
Rated operational current AC-3 400 V Max.
rating for three-phase motors, 50 60 Hz AC-3 230 V Max. rating for three-phase motors, 50 60 Hz AC-3 400 V Max. rating for three-phase motors, 50 60 Hz AC-3 690 V Max. rating for three-phase motors, 50 60 Hz AC-4 230 V Max. rating for three-phase motors, 50 60 Hz AC-4 400 V Max. rating for three-phase motors, 50 60 Hz AC-4 690 V Conventional thermal current I th = I e AC-1 Open For use with Ie P P P P P P Ith = Ie A kW kW kW kW kW kW A 9 2.5 4 4.5 1.5 2.5 3.6 20 DILA-XHI(V)..
General
Standards Lifespan, mechanical AC operated DC operated Operating frequency, mechanical AC operated DC operated Climatic proofing Ambient temperature Open °C -25/60 Operations/h Operations/h 9000 9000 Damp heat, constant, to IEC 60068-2-78 Damp heat, cyclical, to IEC 60068-2-30 Operations Operations Ч 106 Ч 106 10 10 IEC/EN 60947, VDE 0660, UL, CSA
- Тип реле: Contactor
- Внешняя длина / высота: 68 мм
- Внешняя ширина: 45 мм
- External Depth: 125 мм
- Max Contact Voltage AC: 400 В
- Mounting Type: DIN Rail / Panel
- No. of Poles: 3
- Approval Bodies: IEC/EN 60947, VDE0660, UL, CSA
- Dielectric Voltage Coil to Contact: 400 В AC
- Dielectric Voltage Contact to Contact: 400 В AC
- IP Rating: 20
- Max Coil Operating Frequency: 60Hz
- Max Coil Voltage: 240 В AC
- Max Main Contact Current AC1: 20 А
- Max Main Contact Current AC3: 9 А
- Min Coil Operating Frequency: 50Hz
- Min Coil Voltage: 230 В AC
- Power Rating: 4kW
DILM901(230V50HZ,240V60HZ), DILM9 01(230V50HZ,240V60HZ), DILM9-01(230V50HZ240V60HZ), DILM9-01(230V50HZ 240V60HZ)
