Datasheet DILM9-10(110V50HZ,120V60HZ) - Moeller Даташит CONTACTOR, 4KW, WITH 1NO AUX — Даташит
Наименование модели: DILM9-10(110V50HZ,120V60HZ)
DILM910(110V50HZ.120V60HZ) | 316 389 ₽ |
Производитель: Moeller
Описание: CONTACTOR, 4KW, WITH 1NO AUX
Type: DILM9-10(110V50HZ,120V60HZ) Article No.: 276687
Ordering information
Rated operational current AC-3 400 V Max.
rating for three-phase motors, 50 60 Hz AC-3 230 V Max. rating for three-phase motors, 50 60 Hz AC-3 400 V Max. rating for three-phase motors, 50 60 Hz AC-3 690 V Max. rating for three-phase motors, 50 60 Hz AC-4 230 V Max. rating for three-phase motors, 50 60 Hz AC-4 400 V Max. rating for three-phase motors, 50 60 Hz AC-4 690 V Ie P P P P P P A kW kW kW kW kW kW 9 2.5 4 4.5 1.5 2.5 3.6
General
Standards Lifespan, mechanical AC operated DC operated Operating frequency, mechanical AC operated DC operated Climatic proofing Ambient temperature Open Enclosed Storage °C °C °C -25/60 -25/40 -40/80 Operations/h Operations/h 9000 9000 Damp heat, constant, to IEC 60068-2-78 Damp heat, cyclical, to IEC 60068-2-30 Operations Operations Ч 106 Ч 106 10 10 IEC/EN 60947, VDE 0660, UL, CSA
- Тип реле: Contactor
- Внешняя длина / высота: 68 мм
- Внешняя ширина: 45 мм
- External Depth: 125 мм
- Max Contact Voltage AC: 400 В
- Mounting Type: DIN Rail / Panel
- No. of Poles: 3
- Approval Bodies: IEC/EN60947, VDE0660, UL, CSA
- Dielectric Voltage Coil to Contact: 400 В AC
- Dielectric Voltage Contact to Contact: 400 В AC
- IP Rating: 20
- Max Coil Operating Frequency: 60Hz
- Max Coil Voltage: 120 В AC
- Max Main Contact Current AC1: 20 А
- Max Main Contact Current AC3: 9 А
- Min Coil Operating Frequency: 50Hz
- Min Coil Voltage: 110 В AC
- Power Rating: 4kW
DILM910(110V50HZ,120V60HZ), DILM9 10(110V50HZ,120V60HZ), DILM9-10(110V50HZ120V60HZ), DILM9-10(110V50HZ 120V60HZ)
