Datasheet DILM17-10(400V50HZ,440V60HZ) - Moeller Даташит CONTACTOR, 7.5KW, WITH 1NO AUX — Даташит
Наименование модели: DILM17-10(400V50HZ,440V60HZ)
DILM1710(400V50HZ.440V60HZ) | 470 830 ₽ |
Производитель: Moeller
Описание: CONTACTOR, 7.5KW, WITH 1NO AUX
Type: DILM17-10(400V50HZ,440V60HZ) Article No.: 277006
Ordering information
Rated operational current AC-3 400 V Max.
rating for three-phase motors, 50 60 Hz AC-3 230 V Max. rating for three-phase motors, 50 60 Hz AC-3 400 V Max. rating for three-phase motors, 50 60 Hz AC-3 690 V Max. rating for three-phase motors, 50 60 Hz AC-4 230 V Max. rating for three-phase motors, 50 60 Hz AC-4 400 V Max. rating for three-phase motors, 50 60 Hz AC-4 690 V Ie P P P P P P A kW kW kW kW kW kW 18 5 7.5 11 2.5 4.5 6.5
General
Standards Lifespan, mechanical AC operated DC operated Operating frequency, mechanical AC operated DC operated Climatic proofing Ambient temperature Open Enclosed Storage °C °C °C -25/60 -25/40 -40/80 Operations/h Operations/h 5000 5000 Damp heat, constant, to IEC 60068-2-78 Damp heat, cyclical, to IEC 60068-2-30 Operations Operations Ч 106 Ч 106 10 10 IEC/EN 60947, VDE 0660, UL, CSA
- Тип реле: Contactor
- Внешняя длина / высота: 85 мм
- Внешняя ширина: 45 мм
- External Depth: 138 мм
- Contact Current AC Max: 18 А
- Contact Voltage AC Max: 400 В
- Mounting Type: DIN Rail / Panel
- No. of Poles: 3
- Approval Bodies: IEC/EN 60947, VDE0660, UL, CSA
- Coil Frequency Max: 60Hz
- Dielectric Voltage Coil to Contact: 440 В AC
- Dielectric Voltage Contact to Contact: 440 В AC
- IP / NEMA Rating: 00
- Max Coil Voltage: 440 В AC
- Max Main Contact Current AC3: 18 А
- Min Coil Operating Frequency: 50Hz
- Min Coil Voltage: 400 В AC
- Power Rating: 7.5kW
DILM1710(400V50HZ,440V60HZ), DILM17 10(400V50HZ,440V60HZ), DILM17-10(400V50HZ440V60HZ), DILM17-10(400V50HZ 440V60HZ)
