Datasheet DILM32-10(230V50HZ,240V60HZ) - Moeller Даташит CONTACTOR, 15KW, WITH 1NO AUX — Даташит
Наименование модели: DILM32-10(230V50HZ,240V60HZ)
Купить DILM32-10(230V50HZ на РадиоЛоцман.Цены — от 19 375 до 882 226 ₽ Контактор: 3-полюсный; NO x3; Вспомогательные контакты: NO; 32А | |||
DILM32-10-EA(230V50HZ,240V60HZ) Eaton | от 19 375 ₽ | ||
DILM3210(230V50HZ.240V60HZ) | 882 226 ₽ |
Производитель: Moeller
Описание: CONTACTOR, 15KW, WITH 1NO AUX
Type: DILM32-10(230V50HZ,240V60HZ) Article No.: 277260
Ordering information
Rated operational current AC-3 400 V Max.
rating for three-phase motors, 50 60 Hz AC-3 230 V Max. rating for three-phase motors, 50 60 Hz AC-3 400 V Max. rating for three-phase motors, 50 60 Hz AC-3 690 V Max. rating for three-phase motors, 50 60 Hz AC-4 230 V Max. rating for three-phase motors, 50 60 Hz AC-4 400 V Max. rating for three-phase motors, 50 60 Hz AC-4 690 V Conventional thermal current I th = I e AC-1 Open For use with Ie P P P P P P Ith = Ie A kW kW kW kW kW kW A 32 10 15 17 4 7 10 40 DILM32-XHI.. DILA-XHI(V)..
General
Standards Lifespan, mechanical AC operated DC operated Operating frequency, mechanical AC operated DC operated Climatic proofing Ambient temperature Operations/h Operations/h 5000 5000 Damp heat, constant, to IEC 60068-2-78 Damp heat, cyclical, to IEC 60068-2-30 Operations Operations Ч 106 Ч 106 10 10 IEC/EN 60947, VDE 0660, UL, CSA
- Тип реле: Contactor
- Внешняя длина / высота: 85 мм
- Внешняя ширина: 45 мм
- External Depth: 138 мм
- Contact Current AC Max: 32 А
- Contact Voltage AC Max: 400 В
- Mounting Type: DIN Rail / Panel
- No. of Poles: 3
- Approval Bodies: IEC/EN 60947, VDE0660, UL, CSA
- Coil Frequency Max: 60Hz
- Dielectric Voltage Coil to Contact: 440 В AC
- Dielectric Voltage Contact to Contact: 440 В AC
- IP / NEMA Rating: 00
- Max Coil Voltage: 240 В AC
- Max Main Contact Current AC3: 32 А
- Min Coil Operating Frequency: 50Hz
- Min Coil Voltage: 230 В AC
- Power Rating: 15kW
DILM3210(230V50HZ,240V60HZ), DILM32 10(230V50HZ,240V60HZ), DILM32-10(230V50HZ240V60HZ), DILM32-10(230V50HZ 240V60HZ)
