Datasheet DILM12-10(230V50HZ,240V60HZ) - Moeller Даташит CONTACTOR, 5.5KW, WITH 1NO AUX — Даташит
Наименование модели: DILM12-10(230V50HZ,240V60HZ)
Купить DILM12-10(230V50HZ на РадиоЛоцман.Цены — от 5 981 до 364 915 ₽ 8 предложений от 4 поставщиков Контактор 3-полюсный, Вспомогательные контакты NO, 230ВAC, 12А | |||
DILM12-10-EA(230V50HZ,240V60HZ) Eaton | от 5 981 ₽ | ||
DILM12-10-EA(230V50HZ,240V60HZ) Eaton | от 7 388 ₽ | ||
DILM1210(230V50HZ.240V60HZ) | 364 915 ₽ | ||
DILM12-10-EA(230V50HZ,240V60HZ) Eaton | по запросу |
Производитель: Moeller
Описание: CONTACTOR, 5.5KW, WITH 1NO AUX
Type: DILM12-10(230V50HZ,240V60HZ) Article No.: 276830
Ordering information
Rated operational current AC-3 400 V Max.
rating for three-phase motors, 50 60 Hz AC-3 230 V Max. rating for three-phase motors, 50 60 Hz AC-3 400 V Max. rating for three-phase motors, 50 60 Hz AC-3 690 V Max. rating for three-phase motors, 50 60 Hz AC-4 230 V Max. rating for three-phase motors, 50 60 Hz AC-4 400 V Max. rating for three-phase motors, 50 60 Hz AC-4 690 V Conventional thermal current I th = I e AC-1 Open For use with Ie P P P P P P Ith = Ie A kW kW kW kW kW kW A 12 3.5 5.5 6.5 2 3 4.4 20 DILM32-XHI.. DILA-XHI(V)..
General
Standards Lifespan, mechanical AC operated DC operated Operating frequency, mechanical AC operated DC operated Climatic proofing Ambient temperature Operations/h Operations/h 9000 9000 Damp heat, constant, to IEC 60068-2-78 Damp heat, cyclical, to IEC 60068-2-30 Operations Operations Ч 106 Ч 106 10 10 IEC/EN 60947, VDE 0660, UL, CSA
- Тип реле: Contactor
- Внешняя длина / высота: 68 мм
- Внешняя ширина: 45 мм
- External Depth: 125 мм
- Contact Current AC Max: 12 А
- Contact Voltage AC Max: 400 В
- Mounting Type: DIN Rail / Panel
- No. of Poles: 3
- Approval Bodies: IEC/EN 60947, VDE0660, UL, CSA
- Coil Frequency Max: 60Hz
- Coil Operating Frequency Min: 50Hz
- Coil Voltage Max: 240 В AC
- Coil Voltage Min: 230 В AC
- Dielectric Voltage Coil to Contact: 400 В AC
- Dielectric Voltage Contact to Contact: 400 В AC
- IP / NEMA Rating: 20
- Main Contact Current AC3 Max: 12 А
- Power Rating: 5.5kW
DILM1210(230V50HZ,240V60HZ), DILM12 10(230V50HZ,240V60HZ), DILM12-10(230V50HZ240V60HZ), DILM12-10(230V50HZ 240V60HZ)
