Datasheet DILA-22(230V50HZ,240V60HZ) - Moeller Даташит Реле, WITH 2N0+2NC — Даташит
Наименование модели: DILA-22(230V50HZ,240V60HZ)
Купить DILA-22(230V50HZ на РадиоЛоцман.Цены — от 10 982 до 348 386 ₽ Контактор: 4-полюсный; NC x2 + NO x2; 230ВAC; 4А; на DIN-рейку | |||
DILA-22-EA(230V50HZ,240V60HZ) Eaton | от 10 982 ₽ | ||
DILA22(230V50HZ) | 348 386 ₽ |
Производитель: Moeller
Описание: Реле, WITH 2N0+2NC
Type: DILA-22(230V50HZ,240V60HZ) Article No.: 276399
Ordering information
Connection technique Contacts M = Make Contacts B = Break Rated operational current AC15 220 V 230 V 240 V Rated operational current AC15 380 V 400 V 415 V Conventional current, open at 60 °C Distinctive number and version of combination DILA(C)-22 Can be combined with auxiliary contact module Ie Ie Ith A A A Screw terminals 2M 2B 6 4 10 22E DILA-XHI(V)...
Contact sequence
Notes concerning the product group
- Тип реле: Contactor
- Coil Voltage VAC Nom: 240 В
- Contact Current Max: 6 А
- Contact Voltage AC Nom: 415 В
- Contact Configuration: 2 N/0 + 2 N/C
- Coil Type: AC Coil
- Nom Operating Power: 300 мВт
- Relay Mounting: DIN Rail
- Внешняя длина / высота: 68 мм
- Внешняя ширина: 45 мм
- External Depth: 117 мм
- Contact Current AC Max: 6 А
- Contact Current DC Max: 4 А
- Contact Voltage AC Max: 415 В
- Mounting Type: DIN Rail / Panel
- No.
of Poles: 4
- Approval Bodies: IEC/EN 60947, VDE 0660, UL, CSA
- Current Rating: 6 А
- Dielectric Voltage Coil to Contact: 400 В AC
- Dielectric Voltage Contact to Contact: 400 В AC
- Frequency Max: 60Hz
- Frequency Min: 50Hz
- IP / NEMA Rating: IP20
- Input Voltage Max: 240 В AC
- Input Voltage Min: 230 В AC
- Terminal Type: Screw Terminals
DILA22(230V50HZ,240V60HZ), DILA 22(230V50HZ,240V60HZ), DILA-22(230V50HZ240V60HZ), DILA-22(230V50HZ 240V60HZ)
