Datasheet 3RH11221AP00 - Siemens Даташит CONTACTOR, 2NO+2NC — Даташит
Наименование модели: 3RH11221AP00
Купить 3RH11221AP00 на РадиоЛоцман.Цены — от 27 до 3 460 ₽ 8 предложений от 8 поставщиков CONTACTOR RELAY, 2NO+2NC, AC 230 V, 50 HZ, SCREW CONNECTION, SIZE S00 | |||
3RH1122-1AP00 Siemens | 27 ₽ | ||
3RH1122-1AP00 Siemens | 928 ₽ | ||
3RH1122-1AP00 | 2 939 ₽ | ||
3RH1122-1AP00 | 3 460 ₽ |
Производитель: Siemens
Описание: CONTACTOR, 2NO+2NC
3RT, 3RH, 3TB, 3TC, 3TH, 3TK Contactors for Special Applications
Contactors with Extended Tolerance 0.7 ...
1.25 x Us , for Railway Applications
3RT10 motor contactors, 5.5 ... 45 kW
DC operation · DC solenoid system Screw terminals For screw and snap-on mounting onto standard mounting rail Contactor control unit Solenoid fitted with varistor
Rated data AC-2 and AC-3 Tu: up to 70 °C Rated operational current Ie at 400 V A Auxiliary contacts1) Rated control DT supply voltage Us Screw terminals PU PS* (UNIT, SET, M) Price per PU PG Weight per PU approx.
- Тип реле: Contactor
- Coil Voltage VAC Nom: 230 В
- Contact Configuration: 2 N/O + 2 N/C
- Внешняя длина / высота: 57.5 мм
- Внешняя ширина: 45 мм
- External Depth: 106 мм
- Contact Current AC Max: 6 А
- Contact Voltage AC Max: 230 В
- Mounting Type: DIN Rail
- No. of Poles: 4
- Operating Temperature Max: 60°C
- Series: 3RH11
- Temperature Operating Min: -25°C
- Approval Bodies: UL, CSA
- Coil Frequency Max: 60Hz
- Coil Operating Frequency Min: 50Hz
- Dielectric Strength VAC: 600 В AC
- IP / NEMA Rating: 20
- Main Contact Current AC3 Max: 10 А
- Switch Current Max: 10 А
