Datasheet G2RL-1 5DC - Omron Даташит Реле, PCB, SPCO, 5 В DC — Даташит
Наименование модели: G2RL-1 5DC
Купить G2RL-1 5DC на РадиоЛоцман.Цены — от 88 до 9 219 ₽ 9 предложений от 9 поставщиков Power Relay 5VDC 12A SPDT( (29mm 12.7mm 15.7mm)) THT | |||
G2RL15DC Omron | 88 ₽ | ||
G2RL15DC Omron | 96 ₽ | ||
G2RL-1-5DC Omron | 265 ₽ | ||
G2RL15DC | 9 219 ₽ |
Производитель: Omron
Описание: Реле, PCB, SPCO, 5 В DC
PCB Relay
Next-generation PCB Relay Available in 24 Models
Low profile: 15.7 mm max.
in height Contains no lead inside and features cadmium-free contacts ensuring environment-friendly use. Conforms to VDE0435 (VDE approval: C250 insulation grade for flux protection models; B400 insulation grade for fully sealed models), UL508 and CSA22.2. Meets VDE0700 requirements for household products according to VDE0110. Clearance and creepage distance: 10 mm/10 mm. Tracking resistance: CTI>250 (Both standard and class F type) UL1446 Class F Coil Insulation system available. High sensitivity: 400 mW
G2RL
VDE
- Тип реле: Power
- Coil Voltage VDC Nom: 5 В
- Contact Current Max: 12 А
- Contact Voltage AC Nom: 250 В
- Contact Voltage DC Nom: 24 В
- Coil Resistance: 62.5 Ом
- Contact Configuration: SPCO
- Coil Type: DC Coil, Sensitive
- Coil Current: 80 мА
- Nom Operating Power: 400 мВт
- Relay Mounting: PC Board
- Внешняя длина / высота: 15.7 мм
- Внешняя ширина: 12.7 мм
- External Depth: 29 мм
- Contact Current AC Max: 12 А
- Contact Current DC Max: 12 А
- Contact Voltage AC Max: 240 В
- Contact Voltage DC Max: 30 В
- Mounting Type: PCB
- No. of Poles: 1
- Operating Temperature Max: 85В°C
- Series: G2RL
- Temperature Operating Min: -40В°C
- Type: Flux protected
- Approval Bodies: UL, CSA, VDE
- Coil Operating Lower Percent Limit: 70%
- Coil Operating Upper Percent Limit: 130%
- DC Coil Power: 400 мВт
- Operating Time: 7 мс
- Release Time: 5 мс
- Switch Current Max: 12 А
G2RL1 5DC, G2RL 1 5DC
