Datasheet G6C-1117P-US-SV 24DC - Omron Даташит Реле, PCB, SPNO, 24 В DC — Даташит
Наименование модели: G6C-1117P-US-SV 24DC
Power PCB Relay | |||
G6C-1117P-US-SV24DC Omron | по запросу | ||
G6C1117PUSSV24DC Omron | по запросу |
Производитель: Omron
Описание: Реле, PCB, SPNO, 24 В DC
PCB Relay
SPST-NO Type Breaks 10-A Loads; SPST-NO + SPST-NC Type Breaks 8-A Load
I I I I I
G6C
Compact: 20 15 10 mm (L W H).
Low power consumption: 200 mW. Flux protection or fully sealed construction available. Unique moving loop armature reduces relay size, magnetic interference, and contact bounce. Single- and double-winding latching types also available
- Тип реле: Power
- Coil Voltage VDC Nom: 24 В
- Contact Current Max: 10 А
- Contact Voltage AC Nom: 250 В
- Contact Voltage DC Nom: 30 В
- Coil Resistance: 2.88 кОм
- Contact Configuration: SPNO
- Coil Type: DC Coil, Monostable
- Coil Current: 8.3 мА
- Nom Operating Power: 200 мВт
- Relay Mounting: PC Board
- Внешняя длина / высота: 20 мм
- Внешняя ширина: 15 мм
- External Depth: 10 мм
- Contact Current AC Max: 10 А
- Contact Current DC Max: 10 А
- Contact Voltage AC Max: 240 В
- Contact Voltage DC Max: 30 В
- Mounting Type: PCB
- No. of Poles: 1
- Operating Temperature Max: 70°C
- Series: G6C
- Temperature Operating Min: -10°C
- Approval Bodies: UL, CSA, SEV
- Coil Operating Lower Percent Limit: 70%
- Coil Operating Upper Percent Limit: 130%
- Contact Material: Ag Alloy
- DC Coil Power: 200 мВт
- Operating Time: 10 мс
- Release Time: 10 мс
- Switch Current Max: 10 А
Дополнительные аксессуары:
- Omron - P6B-C2
G6C1117PUSSV 24DC, G6C 1117P US SV 24DC
