Datasheet G6D-1A-ASI 24DC - Omron Даташит Реле, PCB, SPCO, 24 В DC — Даташит
Наименование модели: G6D-1A-ASI 24DC
Купить G6D-1A-ASI 24DC на РадиоЛоцман.Цены — от 51 до 6 489 ₽ 20 предложений от 14 поставщиков Универсальное реле, серия G6D-ASI, силовое, без защелки, SPST-NO, 24В DC | |||
G6D1AASI24DC Omron | 51 ₽ | ||
G6D1AASI24DC Omron | 60 ₽ | ||
G6D1AASI24DC Omron | 218 ₽ | ||
G6D-1A-ASI-24DC Omron | 295 ₽ |
Производитель: Omron
Описание: Реле, PCB, SPCO, 24 В DC
PCB Relay
Slim, Miniature Relay, Capable of Relaying Programmable Controller and Temperature Controller Outputs
G6D
Slim and miniature: 17.5 Ч 6.5 Ч 12.5 mm (L Ч W Ч H).
Ideal for high-density mounting. Switches 5 A at 250 VAC/30 VDC. Allows 300,000 operations with a 2-A load at 250 VAC or 30 VDC. Actual load switching capability equals the G6B's capability. Washable construction.
RCE
- Тип реле: Power
- Coil Voltage VDC Nom: 24 В
- Contact Current Max: 5 А
- Contact Voltage AC Nom: 250 В
- Contact Voltage DC Nom: 30 В
- Coil Resistance: 2.88 кОм
- Contact Configuration: SPNO
- Coil Type: DC Coil
- Coil Current: 8.3 мА
- Nom Operating Power: 200 мВт
- Relay Mounting: PC Board
- Внешняя длина / высота: 12.5 мм
- Внешняя ширина: 17.5 мм
- External Depth: 6.5 мм
- Contact Current AC Max: 5 А
- Contact Current DC Max: 5 А
- Contact Voltage AC Max: 250 В
- Contact Voltage DC Max: 30 В
- Mounting Type: PCB
- No. of Poles: 1
- Operating Temperature Max: 70°C
- Series: G6D
- Temperature Operating Min: -25°C
- Approval Bodies: CSA, TUV
- Approval Category: UL Recognised
- Coil Operating Lower Percent Limit: 70%
- Coil Operating Upper Percent Limit: 130%
- Contact Resistance: 100 MOhm
- DC Coil Power: 200 мВт
- Dielectric Voltage Coil to Contact: 3000 В AC
- Dielectric Voltage Contact to Contact: 750 В AC
- Insulation Resistance: 1000 MOhm
- Количество выводов: 4
- Operating Time: 10 мс
- Release Time: 5 мс
- Switch Current Max: 5 А
G6D1AASI 24DC, G6D 1A ASI 24DC
