Datasheet G2R-1-SD-DC12(S) - Omron Даташит Plug-In Relay — Даташит
Наименование модели: G2R-1-SD-DC12(S)
Купить G2R-1-SD-DC12(S) на РадиоЛоцман.Цены — от 667 до 94 471 ₽ 6 предложений от 6 поставщиков Electromechanical Relay 12VDC 278Ω 10A SPDT(29x13x35.5)mm Plug-In General Purpose Relay | |||
G2R1SDDC12S Omron | 667 ₽ | ||
G2R1SDDC12S Omron | 707 ₽ | ||
G2R1SDDC12S Omron | 709 ₽ | ||
G2R-1-SD-DC12(S) Omron | по запросу |
Производитель: Omron
Описание: Plug-In Relay
Power PCB Relay
G2R
· Creepage distance of 8.0 mm (0.31) min.
between coil and contact. · Dual-winding latching type available. · Plug-in and quick-connect terminals available (see G2R-S(S) data sheet). · High sensitivity (360 mW) and high capacity (16 A) types available. · Highly stable magnetic circuit for latching endurance and excellent resistance to vibration and shock. · Safety-oriented design assuring high surge resistance: 10,000 V min. between coil and contacts. · UL, CSA approved, marked with CE.
Ordering Information
To order: Select the part number and add the desired coil voltage rating (e.g., G2R-14-DC12).
- Contacts: SPDT
- Contact Ca
G2R1SDDC12(S), G2R 1 SD DC12(S)
