Datasheet G2R-1A4-DC24 - Omron Даташит POWER Реле SPST-NO 24 В DC, 10 А, PC BOARD — Даташит
Наименование модели: G2R-1A4-DC24
![]() 19 предложений от 15 поставщиков Реле: электромагнитное; SPST-NO; Uобмотки: 24ВDC; 8A/250ВAC; PCB | |||
G2R1A4DC24BYOMI Omron | 347 ₽ | ||
G2R1A4DC24BYOMI Omron | 369 ₽ | ||
G2R-1A4-DC24 | от 880 ₽ | ||
G2R-1A4-DC24 | по запросу |
Производитель: Omron
Описание: POWER Реле SPST-NO 24 В DC, 10 А, PC BOARD
Power PCB Relay
G2R
· Creepage distance of 8.0 mm min.
between coil and contact. · Dual-winding latching type available. · Plug-in and quick-connect terminals available (see G2R-S(S) data sheet). · High sensitivity (360 mW) and high capacity (16 A) types available. · Highly stable magnetic circuit for latching endurance and excellent resistance to vibration and shock. · Safety-oriented design assuring high surge resistance: 10,000 V min. between coil and contacts. · UL recognized / CSA certified. RoHS Complaint
Ordering Information
To order: Select the part number and add the desired coil voltage rating (e.g., G2R-14-DC12).
- Тип реле: General Purpose
- Coil Voltage VDC Nom: 24 В
- Contact Current Max: 10 А
- Contact Voltage AC Nom: 250 В
- Contact Voltage DC Nom: 30 В
- Coil Resistance: 1100 Ом
- Contacts: SPST-NO
G2R1A4DC24, G2R 1A4 DC24
