Datasheet G2R-2-AC120 - Omron Даташит POWER Реле, DPDT, 120VAC, 5 А, PC BOARD — Даташит
Наименование модели: G2R-2-AC120
Купить G2R-2-AC120 на РадиоЛоцман.Цены — от 593 до 78 770 ₽ 11 предложений от 10 поставщиков Реле общего назначения Power PCB Relay DPDT 120VAC Semi-Sealed | |||
G2R2AC120BYOMI Omron | 593 ₽ | ||
G2R2AC120BYOMI Omron | 631 ₽ | ||
G2R-2-AC120 Omron | от 2 886 ₽ | ||
G2R-2-AC120 Omron | по запросу |
Производитель: Omron
Описание: POWER Реле, DPDT, 120VAC, 5 А, PC BOARD
Power PCB Relay
G2R
· Creepage distance of 8.0 mm min.
between coil and contact. · Dual-winding latching type available. · Plug-in and quick-connect terminals available (see G2R-S(S) data sheet). · High sensitivity (360 mW) and high capacity (16 A) types available. · Highly stable magnetic circuit for latching endurance and excellent resistance to vibration and shock. · Safety-oriented design assuring high surge resistance: 10,000 V min. between coil and contacts. · UL recognized / CSA certified. RoHS Complaint
Ordering Information
To order: Select the part number and add the desired coil voltage rating (e.g., G2R-14-DC12).
- Тип реле: General Purpose
- Coil Voltage VAC Nom: 120 В
- Contact Current Max: 5 А
- Contact Voltage AC Nom: 250 В
- Contact Voltage DC Nom: 30 В
- Coil Resistance: 6500 Ом
- Contacts: DPDT
- Coil Type: AC
G2R2AC120, G2R 2 AC120
