Datasheet DILM9-10(400V50HZ,440V60HZ) - Moeller Даташит CONTACTOR, 4 кВт, WITH 1NO AUX — Даташит
Наименование модели: DILM9-10(400V50HZ,440V60HZ)
DILM910(400V50HZ.440V60HZ) | 312 784 ₽ |
Производитель: Moeller
Описание: CONTACTOR, 4 кВт, WITH 1NO AUX
Type: DILM9-10(400V50HZ,440V60HZ) Article No.: 276692
Ordering information
Rated operational current AC-3 400 V Max.
rating for three-phase motors, 50 60 Hz AC-3 230 V Max. rating for three-phase motors, 50 60 Hz AC-3 400 V Max. rating for three-phase motors, 50 60 Hz AC-3 690 V Max. rating for three-phase motors, 50 60 Hz AC-4 230 V Max. rating for three-phase motors, 50 60 Hz AC-4 400 V Max. rating for three-phase motors, 50 60 Hz AC-4 690 V Ie P P P P P P A kW kW kW kW kW kW 9 2.5 4 4.5 1.5 2.5 3.6
General
Standards Lifespan, mechanical AC operated DC operated Operating frequency, mechanical AC operated DC operated Climatic proofing Ambient temperature Open Enclosed Storage °C °C °C -25/60 -25/40 -40/80 Operations/h Operations/h 9000 9000 Damp heat, constant, to IEC 60068-2-78 Damp heat, cyclical, to IEC 60068-2-30 Operations Operations Ч 106 Ч 106 10 10 IEC/EN 60947, VDE 0660, UL, CSA
- Тип реле: Contactor
- Contact Configuration: 1M
- Внешняя длина / высота: 68 мм
- Внешняя ширина: 45 мм
- External Depth: 125 мм
- SVHC: No SVHC (18-Jun-2010)
- Number of Poles: 3
- Approval Bodies: IEC/EN 60947, VDE0660, UL, CSA
- Coil Frequency Max: 60 Гц
- Coil Operating Frequency Min: 50 Гц
- Coil Voltage Max: 440 VAC
- Coil Voltage Min: 400 VAC
- Dielectric Voltage Coil to Contact: 400 VAC
- Dielectric Voltage Contact to Contact: 400 VAC
- IP / NEMA Rating: IP20
- Main Contact Current AC1 Max: 20 А
- Main Contact Current AC3 Max: 9 А
- Power Rating: 4 кВт
DILM910(400V50HZ,440V60HZ), DILM9 10(400V50HZ,440V60HZ), DILM9-10(400V50HZ440V60HZ), DILM9-10(400V50HZ 440V60HZ)
