Datasheet SSU-PAM-SD - Space Age Electronics Даташит Control Relay — Даташит
Наименование модели: SSU-PAM-SD
Купить SSU-PAM-SD на РадиоЛоцман.Цены — от 4 546 до 224 268 ₽ | |||
SSU-PAM-SD | 4 546 ₽ | ||
SSUPAMSD | 224 268 ₽ |
Производитель: Space Age Electronics
Описание: Control Relay
The SSU-PAM-1 Relay provides 10.0 Amp Form C contacts.
The relay may be energized by one of three (3) input voltages: 24VDC, 24VAC, or 120VAC. The DC input voltages are polarity sensitive and diode protected. A red LED is provided which, when illuminated, indicates the relay coil is energized. SAE PN# SSU-PAM-1
Multi-Voltage Relay Modules
PAM
The PAM Series Relays are encapsulated multi-voltage devices with "flying" leads that offer versatile, reliable performance in a convenient package. Several of the versions provide a red LED which, when illuminated, indicates coil energization. The PAM Series Relays are packaged with a self-tapping screw and a piece of double sided tape for easy installation almost anywhere. The relays are also packaged with wire-nuts to aid installation. PAM Relays are ideal for applications where remote relays are required for control or status feedback. They are suitable for use with HVAC, temperature control, fire alarm, security, energy management, lightin
- Coil Voltage VDC Nom: 32 В
- Contact Current Max: 7 А
- Contacts: 1NO/1NC
- Coil Type: DC
- Relay Mounting: Panel
- External Height: 38 мм
- Внешняя ширина: 25 мм
- External Depth: 20 мм
- Depth: 20.64 мм
- Высота: 38.1 мм
- Ширина: 30.16 мм
SSUPAMSD, SSU PAM SD
