Datasheet LM4862M/NOPB - National Semiconductor Даташит усилитель, POWER, аудио, MONO, CLASS AB — Даташит
Наименование модели: LM4862M/NOPB
![]() 35 предложений от 17 поставщиков Усилитель звуковой мощности, 675 мВт, AB, 1 канал, 2.7В до 5.5В, SOIC, 8 вывод(-ов) | |||
LM4862M/NOPB Texas Instruments | 41 ₽ | ||
LM4862M/NOPB Texas Instruments | 57 ₽ | ||
LM4862M/NOPB Texas Instruments | 134 ₽ | ||
LM4862M/NOPB Texas Instruments | от 212 ₽ |
Описание: Усилитель, POWER, аудио, MONO, CLASS AB
LM4862 675 mW Audio Power Amplifier with Shutdown Mode
September 2004
General Description
The LM4862 is a bridge-connected audio power amplifier capable of delivering typically 675mW of continuous average power to an 8 load with 1% THD+N from a 5V power supply.
Boomer audio power amplifiers were designed specifically to provide high quality output power with a minimal amount of external components. Since the LM4862 does not require output coupling capacitors, bootstrap capacitors, or snubber networks, it is optimally suited for low-power portable systems. The LM4862 features an externally controlled, low-power consumption shutdown mode, as well as an internal thermal shutdown protection mechanism. The unity-gain stable LM4862 can be configured by external gain-setting resistors. n Output power at 10% THD+N at 1kHz 8 n Shutdown Current into 825mW (typ) 0.7µA (typ)
- Amplifier Class: AB
- Количество каналов: 1
- Output Power: 675 мВт
- Диапазон напряжения питания: 2.7 В ... 5.5 В
- THD + N: 0.55% @ 500 мВт, 8 Ом, VDD=5V
- Load Impedance: 8 Ом
- Amplifier Case Style: SOIC
- Количество выводов: 8
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: NSOIC
- Bandwidth: 20 кГц
- Семейство: 4862
- Load Impedance Min: 8 Ом
- Number of Amplifiers: 1
- Рабочий диапазон температрур: -40°C ... +85°C
- Output Power Pout: 825 мВт
- Power Rating RMS: 675 мВт
- Supply Voltage + Nom: 6 В
- Способ монтажа: SMD
