Datasheet LMH6321TS/NOPB - National Semiconductor Даташит ИС, HIGH SPEED BUFF, SGL, 110 МГц TO263-7 — Даташит
Наименование модели: LMH6321TS/NOPB
Купить LMH6321TS/NOPB на РадиоЛоцман.Цены — от 174 до 1 692 ₽ 29 предложений от 14 поставщиков TEXAS INSTRUMENTS LMH6321TS/NOPB Buffer Amplifier, High Speed, 1 Amplifiers, 110MHz, 1800V/µs, 5V to ± 16V, TO-263, 7Pins | |||
LMH6321TS/NOPB Texas Instruments | 174 ₽ | ||
LMH6321TS/NOPB Texas Instruments | 203 ₽ | ||
LMH6321TS/NOPB Texas Instruments | от 1 150 ₽ | ||
LMH6321TS/NOPB Texas Instruments | от 1 361 ₽ |
Описание: ИС, HIGH SPEED BUFF, SGL, 110 МГц TO263-7
LMH6321 300 mA High Speed Buffer with Adjustable Current Limit
April 2007
General Description
The LMH6321 is a high speed unity gain buffer that slews at 1800 V/µs and has a small signal bandwidth of 110 MHz while driving a 50 load.
It can drive ±300 mA continuously and will not oscillate while driving large capacitive loads. The LMH6321 features an adjustable current limit. The current limit is continuously adjustable from 10 mA to 300 ma with a ±5 mA ±5% accuracy. The current limit is set by adjusting an external reference current with a resistor. The current can be easily and instantly adjusted, as needed by connecting the resistor to a DAC to form the reference current. The sourcing and sinking currents share the same current limit. The LMH6321 is available in a space saving 8-pin PSOP or a 7-pin TO-263 power package. The PSOP package features an exposed pad on the bottom of the package to increase its heat sinking ca
- Number of Amplifiers: 1
- Gain Bandwidth: 110 МГц
- Slew Rate: 1800 В/мкс
- Диапазон напряжения питания: 5 В ... ± 16 В
- Выходной ток: 300 мА
- Amplifier Output: Single Ended
