Datasheet LTC6101HVACS5 - Linear Technology Даташит ИС, CURRENT с усилитель, HS, TSOT23-5 — Даташит
Наименование модели: LTC6101HVACS5
Купить LTC6101HVACS5 на РадиоЛоцман.Цены — от 149 до 950 ₽ 24 предложений от 17 поставщиков LINEAR TECHNOLOGY LTC6101HVACS5#TRMPBF Current Sense Amplifier, High Voltage, 1 Amplifier, 170nA, TSOT-23, 5Pins, -40℃, 125℃ | |||
LTC6101HVACS5#TRMPBF Analog Devices | 149 ₽ | ||
LTC6101HVACS5#TRPBF Linear Technology | 166 ₽ | ||
LTC6101HVACS5 PBF Linear Technology | по запросу | ||
LTC6101HVACS5#PBF Linear Technology | по запросу |
Производитель: Linear Technology
Описание: ИС, CURRENT с усилитель, HS, TSOT23-5
FEATURES
n
LTC6101/LTC6101HV High Voltage, High-Side Current Sense Amplifier in SOT-23 DESCRIPTION
The LTC®6101/LTC6101HV are versatile, high voltage, high side current sense amplifiers.
Design flexibility is provided by the excellent device characteristics; 300V Max offset and only 375A (typical at 60V) of current consumption. The LTC6101 operates on supplies from 4V to 60V and LTC6101HV operates on supplies from 5V to 100V. The LTC6101 monitors current via the voltage across an external sense resistor (shunt resistor). Internal circuitry converts input voltage to output current, allowing for a small sense signal on a high common mode voltage to be translated into a ground referenced signal. Low DC offset allows the use of a small shunt resistor and large gain-setting resistors. As a result, power loss in the shunt is reduced. The wide operating supply range and high accuracy make the LTC6101 ideal for a large array of applications from automotive to industrial and power management.
- Number of Amplifiers: 1
- Output Current Per Channel: 1 мА
- Input Offset Voltage: 85 мкВ
- Gain dB Max: 100 дБ
- Полоса частот: 200 кГц
- Диапазон напряжения питания: 5 В ... 100 В
- Ток потребления: 350 мкА
- Amplifier Case Style: TSOT-23
- Количество выводов: 5
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: SOT-23
- Семейство: 6101
- Bias Current: 100 нА
- Gain Bandwidth: 140 кГц
- Рабочий диапазон температрур: -40°C ... +125°C
- Способ монтажа: SMD
