Datasheet LMP7731MF/NOPB - National Semiconductor Даташит ИС, операционный усилитель, 22 МГц, 2.4 В/мкс, SOT-23-5 — Даташит
Наименование модели: LMP7731MF/NOPB
Купить LMP7731MF/NOPB на РадиоЛоцман.Цены — от 48 до 315 ₽ 30 предложений от 16 поставщиков ОУх1 Прецизионный: Uпит=2.5...5В; Iпот.канал=2.2мА; Uсм.тип=50мкВ; 2.4В/мкС, f=22МГц, Uш=2.9нВ/Гц R/R-выход | |||
LMP7731MF/NOPB Texas Instruments | 48 ₽ | ||
LMP7731MF/NOPB Texas Instruments | 69 ₽ | ||
LMP7731MF/NOPB Texas Instruments | от 207 ₽ | ||
LMP7731MF/NOPB National Semiconductor | по запросу |
Описание: ИС, операционный усилитель, 22 МГц, 2.4 В/мкс, SOT-23-5
LMP7731, Low Noise, Precision, RRIO Amplifier
June 16, 2008
LMP7731 2.9 nV/sqrt(Hz) Low Noise, Precision, RRIO Amplifier
General Description
The LMP7731 is a single, low noise, low offset voltage, railto-rail input and output, low voltage precision amplifier.
The LMP7731 is part of the LMP® precision amplifier family and is ideal for precision and low noise applications with low voltage requirements. This operational amplifier offers low voltage noise of 2.9 nV/ with a 1/f corner of only 3 Hz and low DC offset with a maximum value of ±40 µV, targeting high accuracy, low frequency applications. The LMP7731 has bipolar input stages with a bias current of only 1.5 nA. This low input bias current, complemented by the very low AC and DC levels of voltage noise, makes the LMP7731 an excellent choice for photometry applications. The LMP7731 provides a wide GBW of 22 MHz while consuming only 2 mA of current. This high gain bandwidth along with the high open loop gain of 130 dB enables accura
- Тип ОУ: Precision
- Количество усилителей: 1
- Полоса частот: 22 МГц
- Скорость нарастания: 2.4 В/мкс
- Диапазон напряжения питания: 1.8 В ... 5.5 В
- Тип корпуса: SOT-23
- Количество выводов: 5
