Datasheet LMC660CN/NOPB - National Semiconductor Даташит ИС, операционный усилитель, 1.4 МГц, 1.1 В/мкс, DIP-14 — Даташит
Наименование модели: LMC660CN/NOPB
Купить LMC660CN/NOPB на РадиоЛоцман.Цены — от 59 до 521 ₽ 26 предложений от 15 поставщиков IC: операционный усилитель; 1,4МГц; Ch: 4; DIP14; 4,75÷15,5ВDC | |||
LMC660CN/NOPB Texas Instruments | 59 ₽ | ||
LMC660CN/NOPB Texas Instruments | 69 ₽ | ||
LMC660CN/NOPB Texas Instruments | от 445 ₽ | ||
LMC660CN/NOPB National Semiconductor | по запросу |
Описание: ИС, операционный усилитель, 1.4 МГц, 1.1 В/мкс, DIP-14
LMC660 CMOS Quad Operational Amplifier
June 2006
General Description
The LMC660 CMOS Quad operational amplifier is ideal for operation from a single supply.
It operates from +5V to +15.5V and features rail-to-rail output swing in addition to an input common-mode range that includes ground. Performance limitations that have plagued CMOS amplifiers in the past are not a problem with this design. Input VOS, drift, and broadband noise as well as voltage gain into realistic loads (2 k and 600) are all equal to or better than widely accepted bipolar equivalents. This chip is built with National's advanced Double-Poly Silicon-Gate CMOS process. See the LMC662 datasheet for a dual CMOS operational amplifier with these same features. n n n n n n n n Low input offset voltage: 3 mV Low offset voltage drift: 1.3 µV/°C Ultra low input bias current: 2 fA Input common-mode range includes V- Operating range from +5V to +15.5V supply ISS = 375 µA/amplifier; inde
- Тип ОУ: High Gain
- Количество усилителей: 4
- Полоса частот: 1.4 МГц
- Скорость нарастания: 1.1 В/мкс
- Диапазон напряжения питания: 5 В ... 15.5 В
- Тип корпуса: DIP
- Количество выводов: 14
