Datasheet LM21212MH-2/NOPB - National Semiconductor Даташит ИС, DC-DC CONV, 1.5 МГц, 20-TSSOP — Даташит
Наименование модели: LM21212MH-2/NOPB
41 предложений от 18 поставщиков
LM21212MH-2/NOPB
501 ₽
LM21212MH-2/NOPB
555 ₽
LM21212MH-2/NOPB
от 896 ₽
LM21212MH-2/NOPB
от 1 683 ₽
Описание: ИС, DC-DC CONV, 1.5 МГц, 20-TSSOP
data sheetСкачать Data Sheet
LM21212-1 12A High Efficiency Synchronous Buck Regulator with Frequency Synchronization
February 25, 2011
General Description
The LM21212-1 is a monolithic synchronous buck regulator that is capable of delivering up to 12A of continuous output current while producing an output voltage down to 0.6V with outstanding efficiency.
The device is optimized to work over an input voltage range of 2.95V to 5.5V, making it suited for a wide variety of low voltage systems. The voltage mode control loop provides high noise immunity, narrow duty cycle capability and can be compensated to be stable with any type of output capacitance, providing maximum flexibility and ease of use. The LM21212-1 features internal over voltage protection (OVP) and over-current protection (OCP) for increased system reliability. A precision enable pin and integrated UVLO allow turn-on of the device to be tightly controlled and seque
  • Входное напряжение минимальное: 5.5 В
  • Выходное напряжение: 5.5 В
  • Выходной ток: 12 А
  • Количество выводов: 20
  • Рабочий диапазон температрур: -40°C ... +125°C
  • Switching Frequency Max: 1.5 МГц
  • Тип корпуса: 20-TSSOP
LM21212MH2/NOPB, LM21212MH 2/NOPB
На английском языке: Datasheet LM21212MH-2/NOPB - National Semiconductor IC, DC-DC CONV, 1.5 MHz, 20-TSSOP
