Datasheet LM21215MH/NOPB - National Semiconductor Даташит ИС, DC-DC CONV, 500 кГц, 20-TSSOP — Даташит
Наименование модели: LM21215MH/NOPB
35 предложений от 19 поставщиков
LM21215MH/NOPB
от 115 ₽
LM21215MH/NOPB
301 ₽
LM21215MH/NOPB
875 ₽
LM21215MH/NOPB
Описание: ИС, DC-DC CONV, 500 кГц, 20-TSSOP
data sheetСкачать Data Sheet
LM21215 15A High Efficiency Synchronous Buck Regulator
February 24, 2011
General Description
The LM21215 is a monolithic synchronous buck regulator that is capable of delivering up to 15A of continuous output current while producing an output voltage down to 0.6V with outstanding efficiency.
The device is optimized to work over an input voltage range of 2.95V to 5.5V, making it suited for a wide variety of low voltage systems. The voltage mode control loop provides high noise immunity, narrow duty cycle capability and can be compensated to be stable with any type of output capacitance, providing maximum flexibility and ease of use. The LM21215 features internal over voltage protection (OVP) and resistor-programmable over-current protection (OCP) for increased system reliability. A precision enable pin and integrated UVLO allow turn-on of the device to be tightly controlled and sequenced. Startup inrush currents are limited by bot
  • Входное напряжение минимальное: 5.5 В
  • Количество выходов: 1
  • Выходное напряжение: 5.5 В
  • Выходной ток: 15 А
  • Количество выводов: 20
  • Рабочий диапазон температрур: -40°C ... +125°C
  • Switching Frequency Max: 500 кГц
На английском языке: Datasheet LM21215MH/NOPB - National Semiconductor IC, DC-DC CONV, 500 kHz, 20-TSSOP
