Datasheet LP8543SQE/NOPB - National Semiconductor Даташит — Даташит
Наименование модели: LP8543SQE/NOPB
IC LED DRIVER RGLTR DIM 24WQFN. LED Driver IC 7 Output DC DC Regulator Step-Up (Boost) PWM Dimming 60mA 24-WQFN (4x4)....
LP8543SQE/NOPB
229 ₽
LP8543SQE/NOPB
262 ₽
727GS
LP8543SQE/NOPB
LP8543SQE/NOPB
data sheetСкачать Data Sheet
LP8543 PRODUCT BRIEF
August 18, 2009
LP8543 PRODUCT BRIEF SMBus/I2C Controlled WLED Driver for Medium Sized LCD Backlight
General Description
The LP8543 is a white LED driver with integrated boost converter.
It has 7 adjustable current sinks which can be controlled by SMBus or I2C-compatible serial interface, PWM input and Ambient Light Sensor (ALS). The boost converter has adaptive output voltage control based on the LED driver voltages. This feature minimizes the power consumption by adjusting the voltage to lowest sufficient level in all conditions. Phase Shift PWM dimming offers further power saving especially when there is poor matching in the forward voltages of the LED strings. Boost voltage can also be controlled through the SMBus/I2C. Internal EEPROM stores the data for backlight brightness and ambient light sensor calibration. Brightness can be calibrated during the backlight unit production so that all units produce the same brightness. EEPROM also stores the coefficients
  • Topology: Boost (Step Up)
  • Количество выходов: 7
  • Выходной ток: 60 мА
  • Входное напряжение: 5.5 В ... 22 В
  • Dimming Control Type: ШИМ
  • Тип корпуса: LLP
  • Peak Reflow Compatible (260 C): Yes
  • Pb-Free: Yes
На английском языке: Datasheet LP8543SQE/NOPB - National Semiconductor
