Datasheet LT1910ES8 - Linear Technology Даташит ИС, полевой транзистор DRIVER, HIGH SIDE, SOIC-8 — Даташит
Наименование модели: LT1910ES8
Купить LT1910ES8 на РадиоЛоцман.Цены — от 69 до 669 ₽45 предложений от 24 поставщиков Интегральные микросхемы Силовые чипы — драйверы затворов | |||
| LT1910ES8#PBF Analog Devices | 222 ₽ | ||
| LT1910ES8 | 485 ₽ | ||
| LT1910ES8 Analog Devices | 669 ₽ | ||
| LT1910ES8#PBF | по запросу | ||
Производитель: Linear Technology
Описание: ИС, полевой транзистор DRIVER, HIGH SIDE, SOIC-8
LT1910 Protected High Side MOSFET Driver FEATURES
n n n n n n n n n n
DESCRIPTION
The LT®1910 is a high side gate driver that allows the use of low cost N-channel power MOSFETs for high side switching applications.
It contains a completely self-contained charge pump to fully enhance an N-channel MOSFET switch with no external components. When the internal drain comparator senses that the switch current has exceeded the preset level, the switch is turned off and a fault flag is asserted. The switch remains off for a period of time set by an external timing capacitor and then automatically attempts to restart. If the fault still exists, this cycle repeats until the fault is removed, thus protecting the MOSFET. The fault flag becomes inactive once the switch restarts successfully. The LT1910 has been specifically designed for harsh operating environments such as industrial, avionics and automotive applications where poor supply regulation and/ or transients may be present. The device wil
- Device Type: High Side
- Module Configuration: High Side
- Input Delay: 220 мкс
- Output Delay: 25 мкс
- Диапазон напряжения питания: 8 В ... 48 В
- Тип корпуса: SOIC
- Количество выводов: 8
