Datasheet MAX13223EEUP+ - Maxim Даташит RS-232 TRANSCEIVER ИС — Даташит
Наименование модели: MAX13223EEUP+
![]() 54 предложений от 22 поставщиков Интегральные микросхемы Интерфейс - Драйверы, Приемники, Трансиверы | |||
MAX13223EEUP+T Maxim | 298 ₽ | ||
MAX13223EEUP+T Maxim | 331 ₽ | ||
MAX13223EEUP Maxim | от 377 ₽ | ||
MAX13223EEUP+T Analog Devices | 817 ₽ |
Производитель: Maxim
Описание: RS-232 TRANSCEIVER ИС
19-4585; Rev 1; 2/11
±70V Fault-Protected, 3.0V to 5.5V, 2Tx/2Rx RS-232 Transceiver
General Description
The MAX13223E is a +3.0V to +5.5V-powered EIA/TIA232 and V.28 communications interface with fault protection on the RS-232 line interface.
This allows shorts of the transmitter outputs and receiver inputs to voltages in the ±70V range without adversely affecting the MAX13223E. The MAX13223E achieves 1µA supply current using Maxim's AutoShutdownTM feature. The MAX13223E automatically enters a low-power shutdown mode when the RS-232 cable is disconnected or the receivers are inactive. The device turns on again when a valid transition at any receiver input is sensed. A proprietary, highefficiency, dual charge-pump power supply and a low-dropout transmitter combine to deliver true RS-232 performance from a single +3.0V to +5.5V supply. The MAX13223E has two receivers and two drivers and is guaranteed to run at data rates of 250kbps for one transmitter switching while maintaining RS-232
