Datasheet MAX201CWE+ - Maxim Даташит ИС RS232 TRANSCEIVER — Даташит
Maxim MAX201CWE+
Наименование модели: MAX201CWE+
29 предложений от 17 поставщиков
MAX201CWE
Maxim
65 ₽
Зенер
Россия и страны ТС
MAX201CWE
Maxim
от 334 ₽
Hi-Tech Circuit Group
MAX201CWE+T
MAX201CWE+
Maxim
Производитель: Maxim
Описание: ИС RS232 TRANSCEIVER
data sheetСкачать Data Sheet
19-0065; Rev 7; 12/05
+5V, RS-232 Transceivers with 0.1µF External Capacitors
General Description
The MAX200­MAX209/MAX211/MAX213 transceivers are designed for RS-232 and V.28 communication interfaces where Q12V supplies are not available.
On-board charge pumps convert the +5V input to the Q10V needed for RS-232 output levels. The MAX201 and MAX209 operate from +5V and +12V, respectively, and contain a +12V to -12V charge-pump voltage converter. The MAX200­MAX209/MAX211/MAX213 drivers and receivers meet all EIA/TIA-232E and CCITT V.28 specifications at a 20kbps data rate. The drivers maintain the Q5V EIA/TIA-232E output signal levels at data rates in excess of 120kbps when loaded in accordance with the EIA/TIA-232E specification. The 5FW shutdown mode of the MAX200, MAX205, MAX206, and MAX211 conserves energy in battery-powered systems. The MAX213 has an active-low shutdown and an active-high receiver enable control. Two receivers of the MAX213 are active, allowing the ring indicator
На английском языке: Datasheet MAX201CWE+ - Maxim IC RS232 TRANSCEIVER
