Datasheet MAX3050ASA+ - Maxim Даташит MAXIM INTEGRATED PRODUCTS — Даташит
Maxim MAX3050ASA+
Наименование модели: MAX3050ASA+
47 предложений от 22 поставщиков
Микросхемы / Контроллеры интерфейсов;Акция! / ;https://testrd.online/files/148702/pdf-148702.pdf;https://testrd.online/files/148702/image-148702.png;Микросхема интерфейсов MAX3050ASA+T
Рутоника
MAX3050ASA+T
Maxim
151 ₽
MAX3050ASA+
Maxim
335 ₽
Эиком
MAX3050ASA+T
от 687 ₽
MAX3050ASA-T
Maxim
Производитель: Maxim
Описание: MAXIM INTEGRATED PRODUCTS
data sheetСкачать Data Sheet
19-2670; Rev 0; 10/02
±80V Fault-Protected, 2Mbps, Low Supply Current CAN Transceivers
General Description
The MAX3050/MAX3057 interface between the CAN protocol controller and the physical wires of the bus lines in a controller area network (CAN).
They are primarily intended for automotive systems requiring data rates up to 2Mbps and feature ±80V fault protection against short circuits in high-voltage power buses. They provide differential transmit capability to the bus and differential receive capability to the CAN controller. The MAX3050/MAX3057 have four modes of operation: high speed, slope control, standby, and shutdown. High-speed mode allows data rates up to 2Mbps. In slope-control mode, data rates are 40kbps to 500kbps, so the effects of EMI are reduced, and unshielded twisted or parallel cable can be used. In standby mode, the transmitters are shut off and the receivers are put into low-current mode. In shutdown mode, the transmitter and receiver are switched off. The MAX305
На английском языке: Datasheet MAX3050ASA+ - Maxim MAXIM INTEGRATED PRODUCTS
