Datasheet MAX4899EETE+ - Maxim Даташит ИС, аналоговый мультиплексор сдвоенный 3X1 — Даташит
Maxim MAX4899EETE+
Наименование модели: MAX4899EETE+
36 предложений от 19 поставщиков
Интегральные микросхемы Интерфейсы и стыки — аналоговые переключатели — специальные
MAX4899EETE+T
Maxim
от 93 ₽
Рутоника
MAX4899EETE+T
Maxim
190 ₽
Зенер
Россия и страны ТС
MAX4899EETE+T
Maxim
от 705 ₽
ТаймЧипс
MAX4899EETE
Maxim
Производитель: Maxim
Описание: ИС, аналоговый мультиплексор сдвоенный 3X1
data sheetСкачать Data Sheet
19-0616; Rev 0; 7/06
KIT ATION EVALU ABLE AVAIL
USB 2.0 High-Speed, Fault-Tolerant 3:1, 4:1 Multiplexers
General Description
The MAX4899E/MAX4899AE analog multiplexers combine the low on-capacitance (CON) and low on-resistance (RON) necessary for high-performance switching applications.
These devices are designed for USB 2.0 high-speed applications at 480Mbps. The MAX4899E/ MAX4899AE also handle all the requirements for USB low- and full-speed signaling. The MAX4899E is a dual 3:1 multiplexer whereas the MAX4899AE is a dual 4:1 multiplexer. The MAX4899E/ MAX4899AE feature two digital inputs, C0 and C1, to control the analog signal path. Typical applications include switching a USB connector between USB and other operations such as serial communications, audio, and video. An enable input (EN) is provided to disable all channels and place the device into a high-impedance (off) state, as well as reducing power consumption. The MAX4899E/MAX4899AE operate from a 2.7V to 3.6V power-supply
На английском языке: Datasheet MAX4899EETE+ - Maxim IC, ANALOG MULTIPLEXER DUAL 3X1
