Datasheet HSCH-5330 - Avago Technologies Даташит Диод, Шоттки — Даташит
Avago Technologies HSCH-5330
Наименование модели: HSCH-5330
13 предложений от 12 поставщиков
TruStability silicon Pressure Sensors: HSC Series-High Accuracy +-1% total Error band,Analog output,SMT and DIP,60 mbar to 10 bar
HSCH-5330
Hi-Tech Circuit Group
HSCH-5330
Broadcom
HSCH-5330
Broadcom
HSCH5330
Производитель: Avago Technologies
Описание: Диод, Шоттки
data sheetСкачать Data Sheet
HSCH-53xx Series
Beam Lead Schottky Diodes for Mixers and Detectors (1-26 GHz)
Data Sheet
Description These beam lead diodes are constructed using a metalsemiconductor Schottky barrier junction.
Advanced epitaxial techniques and precise process control insure uniformity and repeatability of this planar passivated microwave semiconductor. A nitride passivation layer provides immunity from contaminants which could otherwise lead to IR drift. The Avago beam lead process allows for large beam anchor pads for rugged construction (typical 6 gram pull strength) without degrading capacitance. Applications The beam lead diode is ideally suited for use in stripline or microstrip circuits. Its small physical size and uniform dimensions give it low parasitics and repeatable RF characteristics through K-band. The basic medium barrier devices in this family are DC tested HSCH-5310 and -5312. Equivalent low barrier devices are HSCH-5330 and -5332. Batch matched versions are available as HSCH-5331. T
  • Diode Type: Schottky
  • Repetitive Reverse Voltage Vrrm Max: 4 В
  • Forward Voltage VF Max: 375 мВ
  • Рабочий диапазон температрур: -65°C ... +175°C
  • Тип корпуса: 07
  • SVHC: No SVHC (15-Dec-2010)
  • Температура перехода максимальная: 175°C
HSCH5330, HSCH 5330
На английском языке: Datasheet HSCH-5330 - Avago Technologies DIODE, SCHOTTKY
