OKW: приборные корпуса из Германии
Datasheet AD9204 (Analog Devices) - 2
Описание10-Bit, 20 MSPS/40 MSPS/65 MSPS/80 MSPS, 1.8 V Dual Analog-to-Digital Converter
Страниц / Страница37 / 2 — AD9204* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
ВерсияA
AD9204* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. TOOLS AND SIMULATIONS. EVALUATION KITS
AD9204* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS TOOLS AND SIMULATIONS EVALUATION KITS
Электромеханические реле Hongfa – надежность и качество 19 января 2023
View a parametric search of comparable parts. • Visual Analog • AD9204 IBIS Models
EVALUATION KITS
• AD9204/AD9231/AD9251 S-Parameter Data • AD9204 Evaluation Board
REFERENCE MATERIALS DOCUMENTATION Product Selection Guide Application Notes
• RF Source Booklet • AN-1142: Techniques for High Speed ADC PCB Layout
Technical Articles
• AN-742: Frequency Domain Response of Switched- • Improve The Design Of Your Passive Wideband ADC Capacitor ADCs Front-End Network • AN-812: MicroController-Based Serial Port Interface (SPI) • MS-2210: Designing Power Supplies for High Speed ADC Boot Circuit • AN-827: A Resonant Approach to Interfacing Amplifiers to
DESIGN RESOURCES
Switched-Capacitor ADCs • AD9204 Material Declaration • AN-877: Interfacing to High Speed ADCs via SPI • PCN-PDN Information • AN-878: High Speed ADC SPI Control Software • Quality And Reliability • AN-905: Visual Analog Converter Evaluation Tool Version 1.0 User Manual • Symbols and Footprints • AN-935: Designing an ADC Transformer-Coupled Front End
DISCUSSIONS Data Sheet
View all AD9204 EngineerZone Discussions. • AD9204: 10-Bit, 20 MSPS/40 MSPS/65 MSPS/80 MSPS, 1.8 V Dual Analog-to-Digital Converter Data Sheet
SAMPLE AND BUY User Guides
Visit the product page to see pricing options. • UG-003: Evaluating the AD9650/AD9268/AD9258/ AD9251/AD9231/AD9204 Analog-to-Digital Converters
TECHNICAL SUPPORT
Submit a technical question or find your regional support number.
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
Document Outline Features Applications Functional Block Diagram Product Highlights Revision History General Description Specifications DC Specifications AC Specifications Digital Specifications Switching Specifications Timing Specifications Absolute Maximum Ratings Thermal Characteristics ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics AD9204-80 AD9204-65 AD9204-40 AD9204-20 Equivalent Circuits Theory of Operation ADC Architecture Analog Input Considerations Input Common Mode Differential Input Configurations Single-Ended Input Configuration Voltage Reference Internal Reference Connection External Reference Operation Clock Input Considerations Clock Input Options Input Clock Divider Clock Duty Cycle Jitter Considerations Power Dissipation and Standby Mode Digital Outputs Digital Output Enable Function (OEB) Timing Data Clock Output (DCO) Built-In Self-Test (BIST) and Output Test Built-In Self-Test (BIST) Output Test Modes Channel/Chip Synchronization Serial Port Interface (SPI) Configuration Using the SPI Hardware Interface Configuration Without the SPI SPI Accessible Features Memory Map Reading the Memory Map Register Table Open Locations Default Values Logic Levels Transfer Register Map Channel-Specific Registers Memory Map Register Descriptions Sync Control (Register 0x100) Bits[7:3]—Reserved Bit 2—Clock Divider Next Sync Only Bit 1—Clock Divider Sync Enable Bit 0—Master Sync Enable USR2 (Register 0x101) Bit 7—Enable OEB Pin 47 Bit 3—Enable GCLK Detect Bit 2—Run GCLK Bit 0—Disable SDIO Pull-Down Applications Information Design Guidelines Power and Ground Recommendations Exposed Paddle Thermal Heat Sink Recommendations VCM RBIAS Reference Decoupling SPI Port Outline Dimensions Ordering Guide
