Аналоги реле Phoenix Contact, Finder, Omron, ABB, Schneider
Datasheet AD8229-KGD (Analog Devices) - 4
Описание1 nV/√Hz Low Noise 210°C Instrumentation Amplifier
Страниц / Страница8 / 4 — AD8229-KGD. Known Good Die. Parameter. Test Conditions/Comments. Min. …
Формат / Размер файлаPDF / 148 Кб
AD8229-KGD. Known Good Die. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
AD8229-KGD Known Good Die Parameter Test Conditions/Comments Min Typ Max Unit
Какими будут станции зарядки электромобилей в 2030 году: лучшие решения и мировой опыт для отечественных разработок
link to page 5 link to page 5 link to page 5
DYNAMIC RESPONSE Small Signal Bandwidth – 3 dB G = 1 15 MHz G = 10 4 MHz G = 100 1.2 MHz G = 1000 0.15 MHz Settling Time 0.01% 10 V step G = 1 0.75 µs G = 10 0.65 µs G = 100 0.85 µs G = 1000 5 µs Settling Time 0.001% 10 V step G = 1 0.9 µs G = 10 0.9 µs G = 100 1.2 µs G = 1000 7 µs Slew Rate G = 1 to 100 22 V/µs GAIN2 G = 1 + (6 kΩ/R ) G Gain Range 1 1000 V/V Gain Error V = ±10 V OUT G = 1 0.01 0.03 % G = 10 0.05 0.3 % G = 100 0.05 0.3 % G = 1000 0.1 0.3 % Gain Nonlinearity V = −10 V to +10 V OUT G = 1 to 1000 R = 10 kΩ 2 ppm L Gain vs. Temperature G = 1 −40°C to +210°C 2 5 ppm/°C G > 10 −40°C to +210°C −100 ppm/°C INPUT Impedance (Pin to Ground)3 1.5||3 GΩ||pF Input Operating Voltage Range4 V = ±5 V to ±18 V −V + 2.8 +V − 2.5 V S S S for dual supplies Over Temperature −40°C to +210°C −V + 2.8 +V − 2.5 V S S OUTPUT Output Swing R = 2 kΩ −V + 1.9 +Vs − 1.5 V L S High Temperature T = 210°C −V + 1.1 +Vs − 1.1 V A S Output Swing R = 10 kΩ −V + 1.8 +Vs − 1.2 V L S High Temperature T = 210°C −V + 1.1 +Vs − 1.1 V A S Short-Circuit Current 35 mA REFERENCE INPUT R 10 kΩ IN I V +, V − = 0 V 70 µA IN IN IN Voltage Range −V +V V S S Reference Gain to Output 1 V/V Reference Gain Error 0.01 % Rev. 0 | Page 4 of 8 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Absolute Maximum Ratings ESD Caution Pad Configuration and Function Descriptions Outline Dimensions Die Specifications and Assembly Recommendations Ordering Guide
