Datasheet MAX4162, MAX4163, MAX4164 (Maxim) - 4
Производитель | Maxim |
Описание | UCSP, Micropower, Single-Supply, 10V, Rail-to-Rail I/O Op Amps |
Страниц / Страница | 13 / 4 — UCSP, Micropower, Single-Supply, 10V, Rail-to-Rail I/O Op Amps. … |
Формат / Размер файла | PDF / 331 Кб |
Язык документа | английский |
UCSP, Micropower, Single-Supply, 10V, Rail-to-Rail I/O Op Amps. ELECTRICAL CHARACTERISTICS: 5V Operation (continued)
UCSP, Micropower, Single-Supply, 10V, Rail-to-Rail I/O Op Amps ELECTRICAL CHARACTERISTICS: 5V Operation (continued)
(VDD = 5V, VSS = 0V, VCM = VDD/2, VOUT = VDD/2, RL connected to VDD/2, TA = -40°C to +85°C, unless otherwise noted. Typical values are at TA = +25°C.) (Note 1)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
Total Harmonic Distortion THD f = 1kHz, VOUT = 2VP-P, RL = 100kΩ, AV = 1V/V 0.02 % Slew Rate SR 115 V/ms Settling Time to 0.1% VOUT = 1V to 2V step 70 µs Turn-On Time tON VDD = 0 to 3V step, VIN = VDD/2, AV = 1V/V 40 µs Input Voltage-Noise Density en f = 1kHz 80 nV/√Hz Differential Input Capacitance 0.7 pF Input Common-Mode 1.5 pF Capacitance Internal Charge-Pump 700 kHz Frequency Charge-Pump Output 100 µVP-P Feedthrough
Note 1:
All device specifications are 100% tested at TA = +25°C. Limits over the extended temperature range are guaranteed by design, not production tested.
Note 2:
Input bias current guaranteed by design, not production tested.
MAX4162/MAX4163/MAX4164 __________________________________________Typical Operating Characteristics
(VDD = 5V, VSS = 0V, VCM = VDD/2, TA = +25°C, unless otherwise noted.)
SUPPLY CURRENT SUPPLY CURRENT INPUT OFFSET VOLTAGE VARIATION vs. SUPPLY VOLTAGE vs. TEMPERATURE vs. SUPPLY VOLTAGE
30 28 50 26 30 MAX4162-01 MAX4162-02 MAX4162-03 25 24 10 µA) µA) VCC = 5V VCC = 3V -10 20 22 -30 20 µV) 15 ( -50 18 V OS -70 10 16 SUPPLY CURRENT ( SUPPLY CURRENT ( -90 14 -110 5 12 -130 0 10 -150 1 2 3 4 5 6 7 8 9 10 -40 -20 0 20 40 60 80 100 1 2 3 4 5 6 7 8 9 10 SUPPLY VOLTAGE (V) TEMPERATURE (°C) SUPPLY VOLTAGE (V)
4 _______________________________________________________________________________________
