Datasheet RH1965MK DICE/DWF (Analog Devices) - 2
Описание | 0.9A, Low Noise, Low Dropout Linear Regulator |
Страниц / Страница | 8 / 2 — absolute maximum ratings (Note 1). table 1: Dice/DWF electrical test … |
Формат / Размер файла | PDF / 571 Кб |
Язык документа | английский |
absolute maximum ratings (Note 1). table 1: Dice/DWF electrical test limits TA = 25°C (Notes 3, 14, 15, 16) PARAMETER
RH1965MK DICE/DWF
IN Pin Voltage ...±22V OUT Pin Voltage ..±22V Input to Output Differential Voltage (Note 2) ...±22V ADJ Pin Voltage ..±9V SHDN Pin Voltage ...±22V Output Short-Circuit Duration .. Indefinite Operating Junction Temperature Range (Notes 3, 5, 13) ... –55°C to 125°C Storage Temperature Range ... –65°C to 150°C
table 1: Dice/DWF electrical test limits TA = 25°C (Notes 3, 14, 15, 16) PARAMETER CONDITIONS MIN MAX UNITS
ADJ Pin Voltage (Notes 4, 5) VIN = 2.1V, ILOAD = 1mA 1.182 1.218 V Line Regulation ∆VIN = 2.1V to 20V, ILOAD = 1mA (Note 4) 5 mV Load Regulation VIN = 2.3V, ∆ILOAD = 1mA to 50mA (Note 4) 7 mV Dropout Voltage ILOAD = 1mA 0.08 V VIN = VOUT(NOMINAL) (Notes 6, 7, 12) ILOAD = 50mA 0.16 V GND Pin Current ILOAD = 0mA 0.7 mA VIN = VOUT(NOMINAL) + 1V ILOAD = 1mA 1 mA (Notes 6, 8) ILOAD = 100mA 4.5 mA ADJ Pin Bias Current (Notes 4, 9) 4.5 μA Shutdown Threshold VOUT = Off to On 1.2 V VOUT = On to Off 0.43 V SHDN Pin Current (Note 10) VSHDN = 0V 1 μA VSHDN = 20V 10 μA Quiescent Current in Shutdown VIN = 6V, VSHDN = 0V 1 μA Input Reverse-Leakage Current VIN = –20V, VOUT = 0V 1 mA Reverse-Output Current (Note 11) VOUT = 1.2V, VIN = 0V (Note 4) 400 μA rh1965mkf 2 For more information www.linear.com/RH1965MK Document Outline Features Description Dice Pinout Absolute Maximum Ratings Table 1: DICE/DWF Electrical Test Limits Table 2: Electrical Characteristics Table 3: Electrical Characteristics Table 4. Post Burn-In Endpoints and Delta Limit Requirements Table 5. Electrical Test Requirements Total Dose Bias Circuit Burn-In Circuit Typical Performance Characteristics
