Datasheet LTM8064 (Analog Devices) - 4
Описание58VIN, 6A CVCC Step-Down μModule Regulator
Страниц / Страница36 / 4 — e lecTrical characTerisTics The. denotes the specifications which apply …
Формат / Размер файлаPDF / 2.7 Мб
e lecTrical characTerisTics The. denotes the specifications which apply over the specified operating
e lecTrical characTerisTics The denotes the specifications which apply over the specified operating
LTM8064
l
denotes the specifications which apply over the specified operating internal temperature range, otherwise specifications are at TA = 25°C. RUN = 3V unless otherwise noted (Note 3). PARAMETER CONDITIONS MIN TYP MAX UNITS
PGOOD Upper Threshold Voltage FB Rising 1.36 V PGOOD Upper Threshold Hysteresis 40 mV PGOOD Lower Threshold Voltage FB Falling 1.06 V PGOOD Lower Threshold Hysteresis 40 mV PGOOD Sink Current PGOOD = 2V 8 mA PGOOD Leakage Current PGOOD = 6V 1 µA IOUTMON Voltage IOUT = 7.1A 1.27 1.68 V IOUT = 3.55A 0.57 0.96 V
Note 1:
Note 3:
The LTM8064E is guaranteed to meet performance specifications may cause permanent damage to the device. Exposure to any Absolute from 0°C to 125°C internal operating temperature. Specifications over the Maximum Rating condition for extended periods may affect device full –40°C to 125°C internal operating temperature range are assured by reliability and lifetime. design, characterization and correlation with statistical process controls.
Note 2:
This μModule regulator includes overtemperature protection that The LTM8064I is guaranteed to meet specifications over the full –40°C is intended to protect the device during momentary overload conditions. to 125°C internal operating temperature range. Note that the maximum Internal temperature will exceed 125°C when overtemperature protection internal temperature is determined by specific operating conditions in is active. Continuous operation above the specified maximum internal conjunction with board layout, the rated package thermal resistance and temperature may impair device reliability. other environmental factors. 8064fa 4 For more information www.linear.com/LTM8064 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
