Datasheet ADR512W (Analog Devices) - 4
Описание1.2 V Precision Low Noise Shunt Voltage Reference
Страниц / Страница12 / 4 — ADR512W. ABSOLUTE MAXIMUM RATINGS. THERMAL RESISTANCE. Table 2. …
Формат / Размер файлаPDF / 316 Кб
ADR512W. ABSOLUTE MAXIMUM RATINGS. THERMAL RESISTANCE. Table 2. Parameter. Rating. Table 3. Thermal Resistance. Package Type1. θ 2. θJC
ADR512W ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Table 2 Parameter Rating Table 3 Thermal Resistance Package Type1 θ 2 θJC
Пленочные конденсаторы Hongfa для источников питания и силовой электроники (Материалы вебинара)
link to page 4 link to page 4
ADR512W ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Table 2. Parameter Rating
θJA is specified for the worst-case conditions, that is, a device Reverse Current 25 mA soldered in a circuit board for surface-mount packages. Forward Current 20 mA
Storage Temperature Range
Package Type1 θ 2 JA θJC Unit
RT Package −65°C to +150°C 3-SOT-23 (RT) 230 146 °C/W Operating Temperature Range −40°C to +85°C 1Package power dissipation = (TJMAX − TA)/θJA. Junction Temperature Range 2θJA is specified for worst-case conditions; that is., θJA is specified for the device RT Package −65°C to +150°C soldered. Lead Temperature Range (Soldering, 60 Sec) 300°C
ESD CAUTION
Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress rating only; functional operation of the device at these or any other conditions above those indicated in the operational section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Rev. 0 | Page 4 of 12 Document Outline Features Applications Pin Configuration General Description Revision History Specifications Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Terminology Applications Information Adjustable Precision Voltage Source Output Voltage Trim Using the ADR512W with Precision Data Converters Precise Negative Voltage Reference Outline Dimensions Ordering Guide Automotive Products
Электронные компоненты. Скидки 20%, кэшбэк 15% и бесплатная доставка от ТМ Электроникс
