Datasheet RH1028M, RH1128M (Analog Devices) - 5
ОписаниеRadiation Hardened Ultralow Noise Precision High Speed Op Amps
Страниц / Страница6 / 5 — tYpicAl perForMAnce chArActeristics. RH1128 Positive Slew Rate. RH1128 …
Формат / Размер файлаPDF / 282 Кб
tYpicAl perForMAnce chArActeristics. RH1128 Positive Slew Rate. RH1128 Negative Slew Rate. Input Offset Voltage. Open-Loop Gain
tYpicAl perForMAnce chArActeristics RH1128 Positive Slew Rate RH1128 Negative Slew Rate Input Offset Voltage Open-Loop Gain
RH1028M/RH1128M
10 10 20 TA = 25°C TA = 25°C TA = 25°C VS = ±15V VS = ±15V 15 VS = ±15V 9 VOUT = ±10V 9 VOUT = ±10V VCM = 0V AVCL = –1 AVCL = –1 V) 10 /µs) 8 /µs) 8 TAGE (µ 5 TE (V TE (V 7 7 0 –5 +SLEW RA 6 –SLEW RA 6 –10 INPUT OFFSET VOL 5 5 –15 4 4 –20 1 10 100 1000 1 10 100 1000 1 10 100 1000 TOTAL DOSE KRAD (Si) TOTAL DOSE KRAD (Si) TOTAL DOSE KRAD (Si) RH1028 G04 RH1028 G05 RH1028 G06
Open-Loop Gain Input Bias Current Common Mode Rejection Ratio
16 1000 140 TA = 25°C TA = 25°C TA = 25°C V V 14 S = ±15V VS = ±15V 135 S = ±15V RL = 2k VCM = 0V VCM = ±11V V) VOUT = ±10V 500 130 /µ 12 125 10 0 120 8 CMRR (dB) 115 OPEN-LOOP GAIN (V 6 INPUT BIAS CURRENT (nA) –500 110 4 105 2 –1000 100 1 10 100 1000 1 10 100 1000 1 10 100 1000 TOTAL DOSE KRAD (Si) TOTAL DOSE KRAD (Si) TOTAL DOSE KRAD (Si) RH1028 G07 RH1028 G08 RH1028 G09
Input Offset Current Power Supply Rejection Ratio Supply Current
500 150 12 TA = 25°C TA = 25°C TA = 25°C VS = ±15V 145 VS = ±4V TO ±18V 11 VS = ±15V V 300 VCM = 0V OUT = 0V 140 10 100 135 9 130 (mA) 8 I S –100 PSRR (dB) 125 7 120 6 INPUT OFFSET CURRENT (nA) –300 115 5 –500 110 4 1 10 100 1000 1 10 100 1000 1 10 100 1000 TOTAL DOSE KRAD (Si) TOTAL DOSE KRAD (Si) TOTAL DOSE KRAD (Si) RH1028 G10 RH1028 G11 RH1028 G12 rh10281128fe Information furnished by Linear Technology Corporation is believed to be accurate and reliable. However, no responsibility is assumed for its use. Linear Technology Corporation makes no representa- tion that the inter For m connection or of e i its nf cirorm cuits ation www. as described linear. herein com will /R not H1028 infringe M on existing patent rights. 5 Document Outline Description Electrical Characteristics
