Datasheet LT3506, LT3506A (Analog Devices) - 3
ОписаниеDual Monolithic 1.6A Step-Down Switching Regulator
Страниц / Страница24 / 3 — The. ELECTRICAL CHARACTERISTICS. denotes the specifi cations which apply …
Формат / Размер файлаPDF / 221 Кб
The. ELECTRICAL CHARACTERISTICS. denotes the specifi cations which apply over the full operating
The ELECTRICAL CHARACTERISTICS denotes the specifi cations which apply over the full operating
Какими будут станции зарядки электромобилей в 2030 году: лучшие решения и мировой опыт для отечественных разработок
LT3506/LT3506A
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C, VIN = 5V, VBOOST = 8V, unless otherwise noted. (Note 2) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VIN(MIN) Undervoltage Lockout l 3.4 3.6 V IINQ Quiescent Current Not Switching 3.8 4.8 mA IINSD Shutdown Current VRUNSS = 0V 30 45 μA VFB Feedback Voltage –40°C to 85°C, DHD l 792 800 808 mV –40°C to 85°C, EFE l 784 800 816 mV –40°C to 125°C, IFE l 784 800 816 mV IFB FB Pin Bias Current VFB = 800mV, VC = 0.4V l 40 100 nA VFB(REG) Reference Line Regulation VIN = 5V to 25V 0.005 %/V gmEA Error Amp GM 350 μMhos AV Error Amp Voltage Gain 400 IVC VC Source Current VFB = 0.6V, VC = 0V 30 μA VC Sink Current VFB = 1.2V, VC = 1100mV 30 μA VVC(THRESH) VC Switching Threshold 0.7 V VVC(CLAMP) VC Clamp Voltage 1.9 V fSW Switching Frequency LT3506 500 575 650 kHz LT3506A 1 1.1 1.2 MHz Switching Phase (Note 5) 180 Deg DC Maximum Duty Cycle LT3506 89 93 % LT3506A 78 88 % VFB(SWTHRESH) Frequency Shift Threshold on FB 0.4 V fFOLD Foldback Frequency VFB = 0V 170 kHz ISW Switch Current Limit (Note 3) 2.0 2.6 3.6 A VSW(SAT) Switch VCESAT (Note 4) ISW = 1A 210 mV ILSW Switch Leakage Current 10 μA VBOOST(MIN) Minimum Boost Voltage Above Switch ISW = 1A 1.5 2.5 V IBOOST BOOST Pin Current ISW = 1A 20 30 mA IRUN/SS RUN/SS Current 2.1 μA VRUN/SS(THRESH) RUN/SS Threshold 0.3 0.8 V VFB(PGTHRESH) VFB PG Threshold VFB Rising 720 mV VPG(LOW) PG Voltage Output Low VFB = 640mV, IPG = 250μA 0.22 0.4 V ILPG PG Pin Leakage VPG = 2V 0.1 1 μA
Note 1:
Stresses beyond those listed under Absolute Maximum Ratings correlation with statistical process controls. The LT3506I/LT3506AI are may cause permanent damage to the device. Exposure to any Absolute guaranteed and tested over the full –40°C to 125°C operating temperature Maximum Rating condition for extended periods may affect device range. reliability and lifetime.
Note 3:
Current limit is guaranteed by design and/or correlation to static
Note 2:
The LT3506E/LT3506AE are guaranteed to meet performance test. Slope compensation reduces current limit at high duty cycle. specifi cations from 0°C to 85°C. Specifi cations over the –40°C to 85°C
Note 4:
Switch VCESAT guaranteed by design. operating temperature range are assured by design, characterization and
Note 5:
Switching phase is guaranteed by design. 3506afc 3
