Datasheet MAX9000, MAX9001, MAX9002, MAX9003, MAX9004, MAX9005 (Analog Devices) - 2
ОписаниеLow-Power, High-Speed, Single-Supply Op Amp + Comparator + Reference ICs
Страниц / Страница20 / 2 — Low-Power, High-Speed, Single-Supply Op Amp + Comparator + Reference ICs. …
Формат / Размер файлаPDF / 255 Кб
Low-Power, High-Speed, Single-Supply Op Amp + Comparator + Reference ICs. ABSOLUTE MAXIMUM RATINGS
Low-Power, High-Speed, Single-Supply Op Amp + Comparator + Reference ICs ABSOLUTE MAXIMUM RATINGS
Критерии выбора литиевых аккумуляторов и батареек: что необходимо учитывать разработчикам
Supply Voltage (VDD to VSS) ..-0.3V to +6V 10-Pin µMAX (derate 5.6mW/°C above +70°C) ..444mW Voltage Inputs (AIN_, CIN_)...(VSS - 0.3V) to (VDD + 0.3V) 14-Pin SO (derate 8.3mW/°C above +70°C)...667mW Output Short-Circuit Duration (AOUT, COUT, REF) ...Continuous Operating Temperature Range to either VSS or VDD MAX900_E _ _...-40°C to +85°C Continuous Power Dissipation (TA = +70°C) Maximum Junction Temperature ...+150°C 8-Pin SO (derate 5.88mW/°C above +70°C)...471mW Storage Temperature Range ...-65°C to +160°C 8-Pin µMAX (derate 4.1mW/°C above +70°C) ..330mW Lead Temperature (soldering, 10sec) ...+300°C Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability.
ELECTRICAL CHARACTERISTICS
(VDD = +2.5V to +5.5V, VSS = 0, SHDN = VDD (MAX9001/MAX9004 only), VCM(OP AMP) = 0, VAOUT = VDD / 2, VCM(COMP) = 0 (for MAX9001/MAX9002/MAX9004/MAX9005), COUT = low, IOUT(REF) = 0, TA = TMIN to TMAX, unless otherwise noted. Typical values are at VDD = 5V and TA = +25°C.)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
Supply Voltage Range VDD Guaranteed by PSRR tests 2.5 5.5 V
MAX9000–MAX9005
MAX9000/MAX9001/ VDD = 3V 410 500 µA MAX9003/MAX9004 VDD = 5V 450 550 Supply Current IDD VDD = 3V 340 425 MAX9002/MAX9005 µA VDD = 5V 375 475 Supply Current in I MAX9001/MAX9004 (V SHDN SHDN = 0) 2 5 µA Shutdown Shutdown Input Bias IIN( MAX9001/MAX9004 (V SHDN) SHDN = 0 to VDD) 1 2.5 µA Current Shutdown Logic High VIH( 0.7 x V SHDN) DD V Shutdown Logic Low VIL( 0.3 x V SHDN) DD V
OP AMP
Input Offset Voltage VOS MAX900_ES_ ±0.5 ±1.5 mV Input Offset Voltage TCVOS MAX900_ES_ ±1 µV/°C Temperature Coefficient Input Bias Current IBIAS AIN+, AIN- ±0.05 ±2 nA Input Offset Current AIN+, AIN- ±0.02 ±1 nA Input Resistance RIN Differential or common mode 1000 MΩ Input Common-Mode CMVR Guaranteed by CMRR test -0.15 VDD - 1.2 V Voltage Range Common-Mode MAX900_ES_, (VSS - 0.15V) ≤ VCM ≤ (VDD - 1.2V), CMRR 72 96 dB Rejection Ratio VDD = 5.5V Power-Supply Rejection PSRR VDD = 2.5V to 5.5V 74 100 dB Ratio Output Resistance AV = 1V/V 0.01 Ω Output Short-Circuit Shorted to VSS 10 mA Current Shorted to VDD 65 Disabled Mode Output IOUT V SHDN ≤ (0.3V x VDD), VAOUT = 0 to VDD ±0.01 ±1 µA Leakage (DISABLED)
2 _______________________________________________________________________________________
