Datasheets - Светодиодные излучатели - 7
Подраздел: "Светодиодные излучатели"
Найдено: 736 Вывод: 121-140
Вид: Список / Картинки
  1. 5 mm round RGB color LED diode Dimension: 5.0 x 7.6 mm 5.0 mm Round Type, RGB Full Color LED Lamps Diffused and Water clear lens are available Popular T-1 diameter package IC compatible /Low current capability RoHs Compliance
  2. Datasheet LedEngin LZ1-00NW05
    High Luminous Efficacy 5W Neutral White LED
  1. Datasheet American Bright BL-HRGB39P-TRB
    RGB LED device with built-in IC
  2. Datasheet American Bright BL-HRGB32M-TRB
  1. Datasheet American Bright BL-HRGB32K-3-TRB
  2. Datasheet American Bright BL-HJTGTBT39P-TRB
  3. Datasheet American Bright BL-HBGR32L-3-TRB-8
  4. Datasheet American Bright BL-HBGGAJX32K-3-TRB
  5. Datasheet Vishay VLDTG1232G-08
    Dome Lens SMD LED
  6. Datasheet Vishay VLDTG1232R-08
    Dome Lens SMD LED
  7. Dome Lens SMD LED
  8. Datasheet Vishay VLDB1232G-08
    Dome Lens SMD LED
  9. Datasheet Vishay VLDB1232R-08
    Dome Lens SMD LED
  10. Dome Lens SMD LED
  11. Datasheet Arlight ARL-5213RGBC/4C
    Светодиод 5 мм 4 вывода ОБЩИЙ КАТОД, прозрачный RGB, Red-Green 525nm- Blue, 2000-2700mcd
  12. Datasheet Broadcom ASMT-YTB0-0AA02
    PLCC-6 Surface Mount Tricolor LED
  13. PLCC-6 Surface Mount Tricolor LED
  14. Datasheet Avago Technologies ASMT-YTB0-0AA02
  15. PLCC-6 Surface Mount Tricolor LED
  16. Datasheet OSRAM GW QSLR31.EM-K5LW-XX58-1
    New professional mid-power LEDs with long lifetime, high performance and best-in-class reliability OSCONIQ S 3030 is new mid-power LEDs from OSRAM Opto Semiconductors for state-of-the-art professional demands in a wide variety of general lighting ...
