Продам радиокомпоненты бу (были в dip-цоколях). Все проверены.
Микросхемы, все dip: AD669BN Monolithic 16-Bit DACPORT 10шт. AD7837AN Dual 12-Bit MDACs 10шт. DAC8413 (PMI) Quad, 12-Bit DAC Voltage Output with Readback 21шт. DAC8413 (AD) Quad, 12-Bit DAC Voltage Output with Readback 21шт. AD676KD 16-Bit 100 kSPS Sampling ADC 10шт. OP497FP (PMI) Precision Picoampere Input Current Quad Operational Amplifier 35шт. LT1055 Precision, High Speed, JFET Input Operational Amplifiers 40шт. LT1012 Picoamp Input Current, Microvolt Offset, Low Noise Op Amp 90шт. TL074CN LOW NOISE, JFET INPUT OPERATIONAL AMPLIFIERS 10шт. TL072CN Low noise J-FET dual operational amplifiers 10шт. LF398N Sample-and-hold amplifiers 20шт. ADG201 HSJN AD QUAD HIGH SPEED SWITCH 21шт. MAX361CPE Precision, Quad, SPST Analog Switches 7шт. SN74HCT652NT (MALASIA) OCTAL BUS TRANSCEIVERS and REGISTERS WITH 3-STATE OUTPUTS 80шт. CD74HCT74E Flip Flop D-Type Pos-Edge 2-Element 7шт. SN74HCT00N QUADRUPLE 2-INPUT POSITIVE-NAND GATES 7шт. CD74HC00E High-Speed CMOS Logic Quad 2-Input NAND Gate 10шт. 74HC30N 8-INPUT NAND GATE 10шт. CD74HCT30E High Speed CMOS Logic 8-Input NAND Gate 7шт. 74HCT245N Octal 3-State Noninverting Bus Transceiver with LSTTL-Compatible Inputs 42шт. SN74HC245N OCTAL BUS TRANSCEIVERS WITH 3-STATE OUTPUTS 150шт. SN74HCT574 8-BIT D-TYPE FLIP-FLOP 14шт. SN74HC574N OCTAL EDGE-TRIGGERED D-TYPE FLIP-FLOPS WITH 3-STATE OUTPUTS 60шт. 74HCT139N DUAL 2-LINE TO 4-LINE DECODERS/DEMULTIPLEXERS 28шт. 74HCT191N Presettable synchronous 4-bit binary up/down counter 28шт. SN74LS83AN 4-BIT BINARY FULL ADDER WITH FAST CARR 20шт. 74HC688N 8-BIT IDENTITY COMPARATORS 20шт. MAX378CPE High-Voltage, Fault-Protected Analog Multiplexers 10шт. TL7705ACP SUPPLY VOLTAGE SUPERVISORS 10шт. AD688BQ High Precision 10 V Reference 10шт. UNC5801A BiMOS II LATCHED DRIVERS 20шт. GAL16V8B High Performance E2CMOS PLD Generic Array Logic 35шт. GAL18V10 High Performance E2CMOS PLD Generic Array Logic 7шт. X9C104P Digitally Controlled Potentiometer 20шт. NEC D43256 AC-85LL 256k-bit Cmos Static Ram 32k-word By 8-bit 28шт. HP2231 optically coupled logic gates 140шт. CNY74-4 518E TK19 Multichannel Optocoupler with Phototransistor Output 20шт. Реле: Omron G6H-2 12VDC 60шт. MSS7 1A05B (CP Clare) 269шт. Резисторные матрицы: 4116R-001-103 (BC9505) 38шт. Предохранители: предохранитель цилиндрический 1А Типа ВПМ-2 (пластиковый низ) 28шт. |
