Домашний кинотеатр Samsung HT-Z310
5 1
07.07.2016 15:31 #1
No output voltage of the power supply.
In KA5Q1265RF regulator the measured voltages are:
pin 2 ,3, 4, 5 --> 0V
pin 1 ------------> 310V.
Display completely off
unlit display
I changed the photocouplers located near this regulator but even so the device does not turn on
1,233 65
59 33
08.07.2016 09:57 #2
Short circuit in load can be
May be it is useful
Please test R821(may be break), change C822
Тип файла: png KA5Q1265RF.png (21.3 Кб, 0 просмотров)
5 1
09.07.2016 02:09 #3
Форум»Электроника и ...»Аудио» Домашний кинотеатр Samsung HT-Z310 нет власти
As the electric scheme of the device was examined the 10 ohms resistor and capacitor 47uF / 50V on the pin 3 of the regulator and measured voltage less than 1V on this pin.
Аватар для REM69SMAT
650 97
3 1
09.07.2016 16:04 #4
Сообщение от eletmoraes
... and measured voltage less than 1V on this pin.
Cut R821.
Measure him.
This is a standard problem.
Стреляю без предупреждения и без промаха!
Аватар для corbyn50011
Записей в дневнике: 3
894 2,610
22 71
09.07.2016 16:13 #5
http://www.alldatasheet.com/view.jsp...r7AaAtP_8P8HAQ
Часовой пояс GMT +3, время: 07:22.
