Динамик СЧ/НЧ SEAS H1456-08 (ER18RNX)
ER18RNX is an 18 cm (6,5’’) cone driver, developed for use as a long throw high fidelity woofer or woofer/midrange unit.
ТаймЧипс
H1456-5
Tyco
Edge coated reed/paper pulp cone together with perfectly matched moving parts gives a smooth, extended frequency response. Bumped back plate in the magnet system, together with the very long and light weight copper clad aluminium voice coil, allow extreme coil excursion with low distortion.
Heavy copper ring below the T-shaped pole piece will reduce non linear and modulation distortion. Extremely stiff and stable injection moulded metal basket keeps the critical components in perfect alignment. Large windows in the basket both above and below the spider reduce sound reflection, air flow noise and cavity resonance to a minimum.
H145608 (ER18RNX), H1456 08 (ER18RNX)
