1 Flash-Turtle Китай Весь мир | |
TE Connectivity Aerospace, Defense and Marine TX18AB00-1610 TE Connectivity Aerospace, Defense and Marine - 14 Мар 2024 10:03 Olive Drab Connector Backshell, Heat Shrink Adapter 7/8-20 UNEF 16, ... Далее TE Connectivity Aerospace, Defense and Marine TX18AB00-1610Olive Drab Connector Backshell, Heat Shrink Adapter 7/8-20 UNEF 16, 16S | запрос 7 дней склад 6833 шт |
76.8 Ohms ±0 ... Chip Resistor Wide 0604 (1610 Metric), 0406 Anti- ... Далее MCW0406MD7689BP10076.8 Ohms ±0.1% 0.25W, 1/4W Chip Resistor Wide 0604 (1610 Metric), 0406 Anti-Sulfur, Automotive AEC-Q200, Moisture ... | запрос 7 дней склад 35979 шт |
2.8 kOhms ±0 ... Chip Resistor Wide 0604 (1610 Metric), 0406 Anti- ... Далее MCW0406MD2801BP1002.8 kOhms ±0.1% 0.25W, 1/4W Chip Resistor Wide 0604 (1610 Metric), 0406 Anti-Sulfur, Automotive AEC-Q200, Moisture ... | запрос 7 дней склад 41142 шт |
Еще 18 строк | |
8.25 kOhms ± ... Chip Resistor Wide 0604 (1610 Metric), 0406 Anti- ... Далее MCW0406MD8251BP1008.25 kOhms ±0.1% 0.25W, 1/4W Chip Resistor Wide 0604 (1610 Metric), 0406 Anti-Sulfur, Automotive AEC-Q200, Moisture ... | запрос 7 дней склад 21694 шт |
8.87 kOhms ± ... Chip Resistor Wide 0604 (1610 Metric), 0406 Anti- ... Далее MCW0406MD8871BP1008.87 kOhms ±0.1% 0.25W, 1/4W Chip Resistor Wide 0604 (1610 Metric), 0406 Anti-Sulfur, Automotive AEC-Q200, Moisture ... | запрос 7 дней склад 28136 шт |
34.8 kOhms ±0 ... Chip Resistor Wide 0604 (1610 Metric), 0406 Anti- ... Далее MCW0406MD3482BP10034.8 kOhms ±0.1% 0.25W, 1/4W Chip Resistor Wide 0604 (1610 Metric), 0406 Anti-Sulfur, Automotive AEC-Q200, Moisture ... | запрос 7 дней склад 25541 шт |
1.8 Ohms ±1 ... Resistor Wide 0604 (1610 Metric), 0406 Automotive ... Далее RCL04061R80FKEA1.8 Ohms ±1% 0.25W, 1/4W Chip Resistor Wide 0604 (1610 Metric), 0406 Automotive AEC-Q200 Thick Film | запрос 7 дней склад 45748 шт |
6.8 Ohms ±1 ... Resistor Wide 0604 (1610 Metric), 0406 Automotive ... Далее RCL04066R80FKEA6.8 Ohms ±1% 0.25W, 1/4W Chip Resistor Wide 0604 (1610 Metric), 0406 Automotive AEC-Q200 Thick Film | запрос 7 дней склад 5502 шт |
8.06 Ohms & ... Chip Resistor Wide 0604 (1610 Metric), 0406 Automotive ... Далее RCL04068R06FKEA8.06 Ohms ±1% 0.25W, 1/4W Chip Resistor Wide 0604 (1610 Metric), 0406 Automotive AEC-Q200 Thick Film | запрос 7 дней склад 13263 шт |
8.66 Ohms & ... Chip Resistor Wide 0604 (1610 Metric), 0406 Automotive ... Далее RCL04068R66FKEA8.66 Ohms ±1% 0.25W, 1/4W Chip Resistor Wide 0604 (1610 Metric), 0406 Automotive AEC-Q200 Thick Film | запрос 7 дней склад 23748 шт |
17.8 Ohms ±1 ... Resistor Wide 0604 (1610 Metric), 0406 Automotive ... Далее RCL040617R8FKEA17.8 Ohms ±1% 0.25W, 1/4W Chip Resistor Wide 0604 (1610 Metric), 0406 Automotive AEC-Q200 Thick Film | запрос 7 дней склад 19864 шт |
1.8 kOhms ±1 ... Resistor Wide 0604 (1610 Metric), 0406 Automotive ... Далее RCL04061K80FKEA1.8 kOhms ±1% 0.25W, 1/4W Chip Resistor Wide 0604 (1610 Metric), 0406 Automotive AEC-Q200 Thick Film | запрос 7 дней склад 11774 шт |
8.25 kOhms & ... Chip Resistor Wide 0604 (1610 Metric), 0406 Automotive ... Далее RCL04068K25FKEA8.25 kOhms ±1% 0.25W, 1/4W Chip Resistor Wide 0604 (1610 Metric), 0406 Automotive AEC-Q200 Thick Film | запрос 7 дней склад 37825 шт |
8.45 kOhms & ... Chip Resistor Wide 0604 (1610 Metric), 0406 Automotive ... Далее RCL04068K45FKEA8.45 kOhms ±1% 0.25W, 1/4W Chip Resistor Wide 0604 (1610 Metric), 0406 Automotive AEC-Q200 Thick Film | запрос 7 дней склад 25907 шт |
15.8 kOhms ± ... Resistor Wide 0604 (1610 Metric), 0406 Automotive ... Далее RCL040615K8FKEA15.8 kOhms ±1% 0.25W, 1/4W Chip Resistor Wide 0604 (1610 Metric), 0406 Automotive AEC-Q200 Thick Film | запрос 7 дней склад 20880 шт |
69.8 kOhms ± ... Resistor Wide 0604 (1610 Metric), 0406 Automotive ... Далее RCL040669K8FKEA69.8 kOhms ±1% 0.25W, 1/4W Chip Resistor Wide 0604 (1610 Metric), 0406 Automotive AEC-Q200 Thick Film | запрос 7 дней склад 36098 шт |
6.8 kOhms ±5 ... Resistor Wide 0604 (1610 Metric), 0406 Automotive ... Далее RCL04066K80JNEA6.8 kOhms ±5% 0.25W, 1/4W Chip Resistor Wide 0604 (1610 Metric), 0406 Automotive AEC-Q200 Thick Film | запрос 7 дней склад 19077 шт |
1k, 8k Ohm ±0.05% 50mW Power Per Element Voltage Divider 2 ... Далее Y1485V0285AT9W1k, 8k Ohm ±0.05% 50mW Power Per Element Voltage Divider 2 Resistor Network/Array ±2ppm/℃ 1610 J-Lead (3 Terminals) | запрос 7 дней склад 44598 шт |
1k, 8k Ohm ±0.1% 50mW Power Per Element Voltage Divider 2 ... Далее Y4485V0285BA0W1k, 8k Ohm ±0.1% 50mW Power Per Element Voltage Divider 2 Resistor Network/Array ±0.2ppm/℃ 1610 J-Lead (3 Terminals) | запрос 7 дней склад 22811 шт |
Display Modules - LED Character and Numeric Red 7-Segment 2 Character ... Далее LTD-432PCDisplay Modules - LED Character and Numeric Red 7-Segment 2 Character Common Cathode 2.1V 20mA 0.634 H x 0.866 W x 0.319 D (16.10mm x 22. ... | запрос 7 дней склад 9635 шт |
2 AiPCBA Китай Весь мир | |
2 722 ₽ 2-7 дней отгрузка со склада в Китае склад 84 шт | |
3 ChipWorker Китай Весь мир | |
2 804 ₽ 2-7 дней отгрузка со склада в Китае склад 283 шт | |
2 772 ₽ 2-7 дней отгрузка со склада в Китае склад 99 шт | |
36 815 ₽ 2-7 дней отгрузка со склада в Китае склад 241 шт | |
Еще 3 строки | |
41 560 ₽ 2-7 дней отгрузка со склада в Китае склад 230 шт | |
59 424 ₽ 2-7 дней отгрузка со склада в Китае склад 259 шт | |
116 612 ₽ 2-7 дней отгрузка со склада в Китае склад 232 шт | |
4 Akcel Китай Весь мир | |
1610-BL 1/8" PTF Fittings | запрос от 1 шт |
CIRCUIT BREAKER THRM 8A 12VDC | запрос от 1 шт |
... ft); Defined Area: 1610 mm (63.4 ... Yellow; Connection: M12 8-pin 300 mm ... Далее SLLCR14-1610P8 ... : 12 m (40 ft); Defined Area: 1610 mm (63.4 in.); Housing: Yellow; Connection: M12 8-pin 300 mm Pigtail QD; 2x ... | запрос от 1 шт |
Еще 5 строк | |
... ft); Defined Area: 1610 mm (63.4 ... Yellow; Connection: M12 8-pin 300 mm ... Далее SLLCE23-1610P8 ... : 12 m (40 ft); Defined Area: 1610 mm (63.4 in.); Housing: Yellow; Connection: M12 8-pin 300 mm Pigtail QD (89179) | запрос от 1 шт |
... ft); Defined Area: 1610 mm (63.4 ... Yellow; Connection: M12 8-pin 300 mm ... Далее SLLE14-1610P8 ... : 12 m (40 ft); Defined Area: 1610 mm (63.4 in.); Housing: Yellow; Connection: M12 8-pin 300 mm Pigtail QD (88995) | запрос от 1 шт |
TERMINAL BLOCK, BARRIER, 8 POSITION, 16-10AWG; No. of Rows: 2 Row; No. ... Далее 1508STDTERMINAL BLOCK, BARRIER, 8 POSITION, 16-10AWG; No. of Rows: 2 Row; No. of Positions: 8Positions; Wire Size AWG Min:... | запрос от 1 шт |
Weidmüller 2526310000 HS-HF 4.8-9.5/12 MM W Heatshrink marker Fitting ... Далее 2526310000Weidmüller 2526310000 HS-HF 4.8-9.5/12 MM W Heatshrink marker Fitting type: Slide-on Writing area: 16.10 x 12.70 mm Whit | запрос от 1 шт |
118223 - DODGE 118223 2A5.4B5.8-1610 | запрос от 1 шт |
5 Utmel Китай Весь мир | |
CIRCUIT BREAKER THRM 8A 12VDC | 956 ₽ от 1 шт 5-7 дней склад 23 шт |
Еще 3 цен: … 803 ₽ | |
902 ₽ от 10 шт 5-7 дней склад 23 шт | |
851 ₽ от 100 шт 5-7 дней склад 23 шт | |
803 ₽ от 1000 шт 5-7 дней склад 23 шт | |
CIRCUIT BREAKER THRM 8A 32VDC | 956 ₽ от 1 шт 5-7 дней склад 8330 шт |
902 ₽ от 10 шт 5-7 дней склад 8330 шт | |
851 ₽ от 100 шт 5-7 дней склад 8330 шт | |
803 ₽ от 1000 шт 5-7 дней склад 8330 шт | |
CIR BRKR THERM 8A 32VDC | запрос от 1 шт 5-7 дней склад 752 шт |
Еще 2 строки | |
Sensor Cables / Actuator Cables SACB-8/ 16-10,0PUR SCO P | 15 923 ₽ от 1 шт 5-7 дней склад 3 шт |
Еще 3 цен: … 13 369 ₽ | |
15 021 ₽ от 10 шт 5-7 дней склад 3 шт | |
14 171 ₽ от 100 шт 5-7 дней склад 3 шт | |
13 369 ₽ от 1000 шт 5-7 дней склад 3 шт | |
Sensor Cables / Actuator Cables SACB-C-H180-8/ 16-10,0PUR SCO P | 11 157 ₽ от 1 шт 5-7 дней склад 1 шт |
Еще 3 цен: … 9 368 ₽ | |
10 526 ₽ от 10 шт 5-7 дней склад 1 шт | |
9 930 ₽ от 100 шт 5-7 дней склад 1 шт | |
9 368 ₽ от 1000 шт 5-7 дней склад 1 шт | |
6 ТМ Электроникс Санкт-Петербург Россия | |
Наконечник: кольцевой трубчатый; M8; 16мм2; обжим; на провод; медь | 327 ₽ от 2 шт 5-10 дней склад 38 шт |
Еще 2 цен: … 253 ₽ | |
290 ₽ от 20 шт 5-10 дней склад 38 шт | |
253 ₽ от 200 шт 5-10 дней склад 38 шт | |
Наконечник: кольцевой трубчатый; M8; 16мм2; обжим; на провод; медь | 364 ₽ от 1 шт 5-10 дней склад 69 шт |
Еще 2 цен: … 284 ₽ | |
324 ₽ от 10 шт 5-10 дней склад 69 шт | |
284 ₽ от 100 шт 5-10 дней склад 69 шт | |
7 Онлайн Компоненты Москва Россия | |
ABB - THOMAS & BETTS - T16-10 - Клемма с кольцевым наконечником, M10, ... Далее T16-10ABB - THOMAS & BETTS - T16-10 - Клемма с кольцевым наконечником, M10, 3/8", Серия Sta-Kon | 806 ₽ от 1 шт 5-12 дней склад 190 шт |
... Ом, 4.7 ГГц, 1.8 А, 0604 [1610 Метрический], Серия 0604HQ Далее 0604HQ-6N8XJLBWirewound Inductor, 6.8 нГн, 0.035 Ом, 4.7 ГГц, 1.8 А, 0604 [1610 Метрический], Серия 0604HQ | 246 ₽ от 5 шт 5-12 дней склад 1700 шт |
Еще 4 цен: … 117 ₽ | |
190 ₽ от 50 шт 5-12 дней склад 1700 шт | |
172 ₽ от 250 шт 5-12 дней склад 1700 шт | |
155 ₽ от 500 шт 5-12 дней склад 1700 шт | |
117 ₽ от 1000 шт 5-12 дней склад 1700 шт | |
... .032 Ом, 5.8 ГГц, 1.8 А, 0604 [1610 Метрический], Серия 0604HQ Далее 0604HQ-4N5XJLBWirewound Inductor, 4.5 нГн, 0.032 Ом, 5.8 ГГц, 1.8 А, 0604 [1610 Метрический], Серия 0604HQ | 204 ₽ от 5 шт 5-12 дней склад 334 шт |
Еще 7 цен: … 104 ₽ | |
150 ₽ от 50 шт 5-12 дней склад 334 шт | |
141 ₽ от 250 шт 5-12 дней склад 334 шт | |
131 ₽ от 500 шт 5-12 дней склад 334 шт | |
118 ₽ от 1000 шт 5-12 дней склад 334 шт | |
109 ₽ от 2000 шт 5-12 дней склад 334 шт | |
106 ₽ от 10000 шт 5-12 дней склад 334 шт | |
104 ₽ от 20000 шт 5-12 дней склад 334 шт | |
8 Acme Chip Китай Весь мир | |
DIP8 | запрос 7 дней склад 7796 шт |
MSOP8 | запрос 7 дней |
SOP8 | запрос 7 дней склад 74 шт |
9 Энтеро Москва Россия, Белоруссия, Казахстан | |
... лопатка Eternum Baguette 1610-8 используется на предприятиях ... Далее Baguette 1610-8Кондитерская лопатка Eternum Baguette 1610-8 используется на предприятиях общественного питания и в домашних условиях для ... | 4 236 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 500 ₽ |
Вытяжной зонт Cryspi Chef ЗВП 16/10 предназначен для очистки воздуха ... Далее Chef ЗВП 16/10Вытяжной зонт Cryspi Chef ЗВП 16/10 предназначен для очистки воздуха от жира, масла и водяного пара на предприятиях общественного питания и ... | 32 452 ₽ Доставка: есть |
10 Industrial Module Москва Россия | |
Преобразователь UPort 1610-8 USB to 8-port RS-232, 921.6Kbps, ... Далее UPort 1610-8Преобразователь UPort 1610-8 USB to 8-port RS-232, 921.6Kbps, 15KV ESD Protection | запрос 7-28 дней на складе |
Преобразователь UPort 1610-8 USB to 8-port RS-232, 921.6Kbps, ... Далее UPort 1610-8Преобразователь UPort 1610-8 USB to 8-port RS-232, 921.6Kbps, 15KV ESD Protection | 30 772 ₽ 7-28 дней на складе |
8-портовый преобразователь интерфейсов | запрос 7-28 дней на складе |
Еще 16 строк | |
Моноблок HP D5S13EA Pro 3520 AiO G1610 500G 4.0G 8 PC | запрос 7-28 дней на складе |
Моноблок HP D5S13EA Pro 3520 AiO G1610 500G 4.0G 8 PC | 55 002 ₽ 7-28 дней на складе |
Моноблок HP D1T70EA Pro 3520 AiO G1610 500G 2.0G 8 PC | запрос 7-28 дней на складе |
Компьютер HP D1V68EA Pro 3500 MT G1610 500G 4.0G 8 PC | запрос 7-28 дней на складе |
Компьютер HP D1V68EA Pro 3500 MT G1610 500G 4.0G 8 PC | 33 352 ₽ 7-28 дней на складе |
Компьютер HP H4M41EA Pro 3500 MT G1610 500G 2.0G 8 PC | запрос 7-28 дней на складе |
Компьютер HP H4M41EA Pro 3500 MT G1610 500G 2.0G 8 PC | 26 350 ₽ 7-28 дней на складе |
Компьютер HP H4M39EA Pro 3500 MT G1610 500G 4.0G 8 PC | запрос 7-28 дней на складе |
Компьютер HP H4M39EA Pro 3500 MT G1610 500G 4.0G 8 PC | 35 378 ₽ 7-28 дней на складе |
HP Business Desktop Pro 6300 Desktop Computer - Intel Celeron G1610 2. ... Далее F2W01US#ABAHP Business Desktop Pro 6300 Desktop Computer - Intel Celeron G1610 2.60 GHz - Small Form Factor - 8 GB RAM - 500 GB HDD - Intel HD Graphics ... | запрос 7-28 дней на складе |
HP Business Desktop Pro 6300 Desktop Computer - Intel Celeron G1610 2. ... Далее F2W01US#ABAHP Business Desktop Pro 6300 Desktop Computer - Intel Celeron G1610 2.60 GHz - Small Form Factor - 8 GB RAM - 500 GB HDD - Intel HD Graphics ... | 92.1 ₽ 7-28 дней на складе |
Моноблок HP E4Z18EA 6300P AiO G1610 500G 4.0G 8 PC | запрос 7-28 дней на складе |
Моноблок HP E4Z18EA 6300P AiO G1610 500G 4.0G 8 PC | 61 175 ₽ 7-28 дней на складе |
Компьютер HP H5S68ES 6300 Pro SFF Celeron G1610 2GB PC3-1600,500GB ... Далее H5S68ESКомпьютер HP H5S68ES 6300 Pro SFF Celeron G1610 2GB PC3-1600,500GB SATA HDD, no ODD,keyboard,mouse,GigLAN, TPM, Win8 Pro 64 downgrade to ... | запрос 7-28 дней на складе |
Компьютер HP H5S68ES 6300 Pro SFF Celeron G1610 2GB PC3-1600,500GB ... Далее H5S68ESКомпьютер HP H5S68ES 6300 Pro SFF Celeron G1610 2GB PC3-1600,500GB SATA HDD, no ODD,keyboard,mouse,GigLAN, TPM, Win8 Pro 64 downgrade to ... | 41 551 ₽ 7-28 дней на складе |
11 AMANA Москва Россия и страны СНГ | |
... изделий Eternum Baguette 1610-8, которая станет неотъемлемым ... Далее Baguette 1610-8Представляем лопатку для кондитерских изделий Eternum Baguette 1610-8, которая станет неотъемлемым аксессуаром как на профессиональной кухне ... | 4 267 ₽ Любая оплата без комиссии.... Далее Любая оплата без комиссии. Самовывоз по предоплате Доставка: есть 1-3 дня на складе |
Зонт приточно-вытяжной Restoinox ЗПВПК-16/10 пристенного типа. ... Далее ЗПВПК-16/10Зонт приточно-вытяжной Restoinox ЗПВПК-16/10 пристенного типа. Устанавливается над варочными поверхностями и другим тепловым оборудованием ... | 48 052 ₽ Любая оплата без комиссии.... Далее Любая оплата без комиссии. Самовывоз по предоплате Доставка: есть 1-3 дня - |
Вытяжной зонт CRYSPI Chef ЗВП 16/10 пристенного типа. Устанавливается ... Далее Chef ЗВП 16/10Вытяжной зонт CRYSPI Chef ЗВП 16/10 пристенного типа. Устанавливается над варочными поверхностями и другим тепловым оборудованием на ... | 32 452 ₽ Любая оплата без комиссии.... Далее Любая оплата без комиссии. Самовывоз по предоплате Доставка: есть 1-3 дня - |
12 ЧипСити Москва Россия | |
ETA 1610-8-WAY BASE & LID Fuse Accessory, Base, Mounting, 1610 Series | 2 557 ₽ 3-7 дней склад 1221 шт |
CIRCUIT BREAKER BASE 1610 | 2 586 ₽ 3-7 дней склад 146 шт |
Circuit Breaker Thrm 8A 32VDC | 184 ₽ 3-7 дней склад 1009 шт |
Еще 6 строк | |
Thermal Circuit Breaker, 28VDC, 8A, 1Pole, Auto Fuse Holder | 849 ₽ 3-7 дней склад 252 шт |
Circuit Breaker; Therm; Press-to-Reset; Cur-Rtg 8A; Socket; 1Pole; Vol ... Далее 1610-92-8ACircuit Breaker; Therm; Press-to-Reset; Cur-Rtg 8A; Socket; 1Pole; Vol-Rtg 12VDC | 532 ₽ 3-7 дней склад 912 шт |
Automotive circuit breakers [ETA] 1610-H2-8, 0A Automotive circuit ... Далее 1610-H2-8, 0AAutomotive circuit breakers [ETA] 1610-H2-8, 0A Automotive circuit breakers | 1 507 ₽ 3-7 дней склад 320 шт |
Automotive circuit breakers [ETA] 1610-21-8, 0A Automotive circuit ... Далее 1610-21-8, 0AAutomotive circuit breakers [ETA] 1610-21-8, 0A Automotive circuit breakers | 1 542 ₽ 3-7 дней склад 345 шт |
Ring Tongue Terminal, Sta-Kon Series, 3/8 , M10, Uninsulated | 1 510 ₽ 3-7 дней склад 222 шт |
FIFO Mem Async Dual Uni-Dir 5K x 16/10K x 8 44-Pin TSOP-II | 2 208 ₽ 3-7 дней склад 150 шт |
13 ЕКОМП Санкт-Петербург Россия | |
Диагональ:12,1 дюйма; Габариты:8.7 x 277.7 x 180.6; Разрешение: ... Далее TFT дисплей NEC NL12880AC20-20DДиагональ:12,1 дюйма; Габариты:8.7 x 277.7 x 180.6; Разрешение:1280x800; 16:10; Кол-во цветов 16.7M/ 262k; Яркость 400 кд/м; LVDS; ... | 14 014 ₽ 100% предоплата Доставка: есть... Далее 100% предоплата Доставка: есть Самовывоз: нет 1-3 дня на складе |
14 Кремний Санкт-Петербург Россия и страны СНГ | |
запрос 2 недели | |
15 Ресторан Комплект Люберцы, Московская обл. Россия | |
... LIEBHERR FKUV 1610 купить в ... . ☎ 8(499) 110-34-55, 8(800) 500 ... Далее Шкаф холодильный LIEBHERR FKUV 1610 ... FKUV 1610 купить в интернет-магазине Ресторан Комплект ✔ Цена, характеристики, сравнение, фото, руководство. Доставка и гарантия. ☎ 8(499 ... | 98 064 ₽ на складе |
... пиццы KORECO SPZ 1610 WN купить в ... . ☎ 8(499) 110-34-55, 8(800) 500 ... Далее Стол холодильный для пиццы KORECO SPZ 1610 WN ... холодильный для пиццы KORECO SPZ 1610 WN купить в интернет-магазине ... руководство. Доставка и гарантия. ☎ 8(499) 110-34-55, 8(800) 500-50-62 | 192 756 ₽ на складе |
16 ЭлектроПласт Санкт-Петербург Россия | |
98-0798-1610-8 27 Апр 2024 02:07 | запрос 7-14 дней |
HA2-1610-8 27 Апр 2024 02:07 | запрос 7-14 дней |
Beryllia Core, Silicone Coated Power Resistors MIL-R-26 (RW) & ... Далее B-1610-1-8Beryllia Core, Silicone Coated Power Resistors MIL-R-26 (RW) & Commercial Industrial Styles | запрос 7-14 дней |
17 Холодильник.ру Москва Россия | |
Размер диагонали (): 23.8
Разрешение экрана: 1920x1080
Тип процессора: ... Далее Моноблок ACER Aspire C24-1610, 23.8/'/', Full HD (DQ.BLACD.001), черныйРазмер диагонали (): 23.8
Тип процессора: Intel Nseries
Жесткий диск (Гб): 256
Размер оперативной памяти (Мб): ... | 45 990 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 400 ₽ - |
Тип процессора: ... Далее Моноблок ACER Aspire C24-1610, 23.8/'/', Full HD (DQ.BLBCD.001), черныйРазмер диагонали (): 23.8
Размер оперативной памяти (Мб): ... | 49 990 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 400 ₽ - |
18 Оптулс Москва Россия | |
515.1610 KS TOOLS Головка 3/8" шестигранная, удлиненная CrMo | 726 ₽ Розница, Скидки для Дилеров - |
BWTSP1610 BAHCO 3/8" Торцевая головка с винтовой резьбой, 10мм | 2 831 ₽ Розница, Скидки для Дилеров - |
19 LifeElectronics Санкт-Петербург Россия | |
Химикаты 99.8% IPA WIPE 5 X 8 REFILL ROLLS 100CT | запрос 7-14 дней |
Цилиндрические метрические разъемы SACB-C-H180-8/ 16-10.0PUR | запрос 7-14 дней |
20 МосЧип Москва Россия | |
Химикаты Iso Alcohol 99.8% 4 gal/carton | запрос 7-14 дней |
Low Profile 7/8 Diameter Single Turn Conductive Plastic Bronze Bearing ... Далее 6130-01-015-1610Low Profile 7/8 Diameter Single Turn Conductive Plastic Bronze Bearing Position Sensor Precision Potentiometer | запрос 7-14 дней |
SFP-TR3-1610-APD-C 27 Апр 2024 02:07 8-Channel SDI/ASI Multiplexer/Demultiplexer | запрос 7-14 дней |
Еще 1 строка | |
Цилиндрические метрические разъемы SACB-8/ 16-10,0PUR SCO P | запрос 7-14 дней |
21 Океан Электроники Санкт-Петербург Россия | |
Химикаты Iso Alcohol 99.8% 5 gal | запрос 7-14 дней |
22 ЭИК Санкт-Петербург Россия | |
CIR BRKR THERM 8A 32VDC | 2 200 ₽ от 1 шт 21-42 дня склад 139 шт |
Еще 4 цен: … 1 335 ₽ | |
2 121 ₽ от 5 шт 21-42 дня склад 139 шт | |
2 042 ₽ от 10 шт 21-42 дня склад 139 шт | |
1 571 ₽ от 50 шт 21-42 дня склад 139 шт | |
1 335 ₽ от 100 шт 21-42 дня склад 139 шт | |
CIRCUIT BREAKER THRM 8A 12VDC | 2 200 ₽ от 1 шт 21-42 дня склад 23 шт |
2 121 ₽ от 5 шт 21-42 дня склад 23 шт | |
2 042 ₽ от 10 шт 21-42 дня склад 23 шт | |
1 571 ₽ от 50 шт 21-42 дня склад 23 шт | |
1 335 ₽ от 100 шт 21-42 дня склад 23 шт | |
CIRCUIT BREAKER THRM 8A 32VDC | 2 200 ₽ от 1 шт 21-42 дня склад 696 шт |
2 121 ₽ от 5 шт 21-42 дня склад 696 шт | |
2 042 ₽ от 10 шт 21-42 дня склад 696 шт | |
1 571 ₽ от 50 шт 21-42 дня склад 696 шт | |
1 335 ₽ от 100 шт 21-42 дня склад 696 шт | |
Еще 2 строки | |
Корпус: BOX PLAS OFF WHT 10"L X 8.030"W | 19 144 ₽ от 1 шт 21-42 дня склад 4 шт |
Еще 2 цен: … 14 890 ₽ | |
15 956 ₽ от 5 шт 21-42 дня склад 4 шт | |
14 890 ₽ от 25 шт 21-42 дня склад 4 шт | |
3/8" ELBOW FITTING | 13 986 ₽ от 1 шт 21-42 дня склад 30 шт |
23 Стандарт СИЗ Москва Россия Только юр.лица Безнал. расчет Заказ от 5000 руб. Строка от 400 руб. | |
Кабельный ввод, 1 шт. Каб.ввод IP68; резьба: PG 16 x 9.5; каб. d: 11~7 ... Далее PBA16-10Кабельный ввод, 1 шт. Каб.ввод IP68; резьба: PG 16 x 9.5; каб. d: 11~7 мм; приб. отв. d: 22.5~22.8 мм; цанга: разъемная; раб. T: -40C ~ + ... | 243 ₽ от 5000 ₽ |
24 ЭКиТ Москва Россия Только юр.лица Безнал. расчет Филиалы: Санкт-Петербург Ростов-на-Дону Челябинск | |
Каб.ввод IP68; резьба: M16 x 1.5 x 8; каб. d: 10~5 мм; приб. отв. d: ... Далее CCMA16-10Каб.ввод IP68; резьба: M16 x 1.5 x 8; каб. d: 10~5 мм; приб. отв. d: 12 мм, A/F 18/20; раб. T: -40C ~ +100C; мат.: никелированная латунь; ... | 222 ₽ склад 100 шт |
Каб.ввод IP68; резьба: PG 16 x 9.5; каб. d: 11~7 мм; приб. отв. d: 22. ... Далее PBA16-10Каб.ввод IP68; резьба: PG 16 x 9.5; каб. d: 11~7 мм; приб. отв. d: 22.5~22.8 мм; цанга: разъемная; раб. T: -40C ~ +100C(+120C); мат.: A,C,F ... | 979 ₽ склад 46 шт |
25 Триема Воронеж Россия Филиалы: Москва Белгород Курск Липецк Орел Тула | |
Фреза твердосплавная с тороидальным торцем для высокопроизводительной ... Далее Фреза (206510 16/1, 0)Фреза твердосплавная с тороидальным торцем для высокопроизводительной работы 16/1,0 мм. хвостовик HA с допуском h6. Угол подъёма спирали - ... | 46 914 ₽ Доставка: есть Самовывоз: есть на складе |
Фреза с тороидальным торцом твердосплавная для высокопроизводительной ... Далее Фреза (206422 16/1, 0)Фреза с тороидальным торцом твердосплавная для высокопроизводительной работы 16/1,0 мм. Число зубьев - 8. Угол подъёма спирали - 45 градусов ... | 49 796 ₽ Доставка: есть Самовывоз: есть на складе |
Твердосплавная фреза l с тороидальным торцом для ... Далее Фреза (206354 16/1, 0)Твердосплавная фреза l с тороидальным торцом для высокопроизводительной работы 16/1,0 мм. Длина вылета с обнизкой - 42 мм. радиус режущей ... | 30 711 ₽ Доставка: есть Самовывоз: есть на складе |
Еще 9 строк | |
Твердосплавная фреза l с тороидальным торцом для ... Далее Фреза (206335 16/1, 0)Твердосплавная фреза l с тороидальным торцом для высокопроизводительной работы 16/1,0 мм. длина рабочей части - 16 мм. Макс. диаметр обнизки ... | 46 056 ₽ Доставка: есть Самовывоз: есть на складе |
Твердосплавная фреза с тороидальным торцом для высокопроизводительной ... Далее Фреза (206257 16/1, 0)Твердосплавная фреза с тороидальным торцом для высокопроизводительной работы 16/1,0 мм. Общая длина - 108 мм. Длина вылета с обнизкой - 58 ... | 36 494 ₽ Доставка: есть Самовывоз: есть на складе |
Твердосплавная фреза с тороидальным торцом для высокопроизводительной ... Далее Фреза (206255 16/1, 0)Твердосплавная фреза с тороидальным торцом для высокопроизводительной работы 16/1,0 мм. Угол подъёма спирали - 42 градусов. Общая длина - 92 ... | 30 385 ₽ Доставка: есть Самовывоз: есть на складе |
Каб.ввод IP68; резьба: M16 x 1.5 x 8; каб. d: 10~5 мм; приб. отв. d: ... Далее CCMA16-10Каб.ввод IP68; резьба: M16 x 1.5 x 8; каб. d: 10~5 мм; приб. отв. d: 12 мм, A/F 18/20; раб. T: -40C ~ +100C; мат.: никелированная латунь; ... | 290 ₽ Доставка: есть Самовывоз: есть на складе |
Каб.ввод IP68; резьба: PG 16 x 9.5; каб. d: 11~7 мм; приб. отв. d: 22. ... Далее PBA16-10Каб.ввод IP68; резьба: PG 16 x 9.5; каб. d: 11~7 мм; приб. отв. d: 22.5~22.8 мм; цанга: разъемная; раб. T: -40C ~ +100C(+120C); мат.: A,C,F ... | 1 289 ₽ Доставка: есть Самовывоз: есть на складе |
Для зачистки и обрезки кабеля.Длина: 160 ммВес: 0,21 кгТип инструмента ... Далее CP-412GДля зачистки и обрезки кабеля.Длина: 160 ммВес: 0,21 кгТип инструмента: Инструмент многоцелевой усиленный для зачистки и обжима серии CP- ... | 677 ₽ Доставка: есть Самовывоз: есть на складе |
Диагональ:12,1 дюйма Габариты:8.7 x 277.7 x 180.6 Разрешение:1280x800 ... Далее NL12880AC20-20DДиагональ:12,1 дюйма Габариты:8.7 x 277.7 x 180.6 Разрешение:1280x800 16:10 Кол-во цветов 16.7M/ 262k Яркость 400 кд/м LVDS Температурный ... | 20 114 ₽ Доставка: есть Самовывоз: есть на складе |
Диагональ:12.1 дюйма (31см) Габариты:8.7 x 277.7 x 180.6 Разрешение: ... Далее NL12880BC20-07FДиагональ:12.1 дюйма (31см) Габариты:8.7 x 277.7 x 180.6 Разрешение:1280х800 16:10 Яркость 1500 кд/м2, Контрастность 800:1, LVDS, Раб. Тем ... | 43 462 ₽ Доставка: есть Самовывоз: есть на складе |
Диагональ:12,1 дюйма; Габариты:8.7 x 277.7 x 180.6; Разрешение: ... Далее NL12880AC20-20DДиагональ:12,1 дюйма; Габариты:8.7 x 277.7 x 180.6; Разрешение:1280x800; 16:10; Кол-во цветов 16.7M/ 262k; Яркость 400 кд/м; LVDS; ... | 24 151 ₽ Доставка: есть Самовывоз: есть на складе |
26 Аудиомания Москва Россия, Беларусь, Казахстан | |
Проекционный экран, блокирующий внешнюю засветку, постоянное натяжение ... Далее Radiance Thin Bezel (16:10) 106 143x228Проекционный экран, блокирующий внешнюю засветку, постоянное натяжение, соотношение сторон 16:10, полотно Radiance, коэффициент отражения 0. ... | 244 400 ₽ Доставка: есть Самовывоз: есть на складе |
Проекционный экран, блокирующий внешнюю засветку, постоянное натяжение ... Далее Radiance Thin Bezel (16:10) 93 127x203Проекционный экран, блокирующий внешнюю засветку, постоянное натяжение, соотношение сторон 16:10, полотно Radiance, коэффициент отражения 0. ... | 220 900 ₽ Доставка: есть Самовывоз: есть на складе |
Проекционный экран, блокирующий внешнюю засветку, постоянное натяжение ... Далее Radiance Thin Bezel (16:10) 80 108x172Проекционный экран, блокирующий внешнюю засветку, постоянное натяжение, соотношение сторон 16:10, полотно Radiance, коэффициент отражения 0. ... | 247 502 ₽ Доставка: есть Самовывоз: есть - |
Еще 3 строки | |
Проекционный экран, блокирующий внешнюю засветку, постоянное натяжение ... Далее Radiance Thin Bezel (16:10) 110 148x237Проекционный экран, блокирующий внешнюю засветку, постоянное натяжение, соотношение сторон 16:10, полотно Radiance, коэффициент отражения 0. ... | 358 234 ₽ Доставка: есть Самовывоз: есть - |
Проекционный экран, блокирующий внешнюю засветку, постоянное натяжение ... Далее Radiance Thin Bezel (16:10) 100 135x215Проекционный экран, блокирующий внешнюю засветку, постоянное натяжение, соотношение сторон 16:10, полотно Radiance, коэффициент отражения 0. ... | 230 300 ₽ Доставка: есть Самовывоз: есть на складе |
Проекционный экран, блокирующий внешнюю засветку, электропривод, ... Далее Radiance Control (16:9) 106 132x234Проекционный экран, блокирующий внешнюю засветку, электропривод, соотношение сторон 16:10, полотно Radiance, коэффициент отражения 0.8, ... | 453 268 ₽ Доставка: есть Самовывоз: есть - |
27 ВсеИнструменты.ру Москва Россия | |
... P0.8-25 (10000 шт; 0.84х25 мм) Pegas pneumatic PGS-1610 Далее Шпилька Pegas pneumaticШпилька P0.8-25 (10000 шт; 0.84х25 мм) Pegas pneumatic PGS-1610 | 977 ₽ на складе |
... ВТМ (S) ПМЛ-1610-12А-24АС-(2з)-РТЛ1012- ... 2(5,5-8,0А)-У2-В ВТМ00054384 Далее Пускатель ВТМ - ВТМ00054384Пускатель ВТМ (S) ПМЛ-1610-12А-24АС-(2з)-РТЛ1012-2(5,5-8,0А)-У2-В ВТМ00054384 | 5 749 ₽ на складе |
... ВТМ (S) ПМЛ-1610-12А-42АС-(2з)-РТЛ1012- ... 2(5,5-8,0А)-У2-А ВТМ00054446 Далее Пускатель ВТМ - ВТМ00054446Пускатель ВТМ (S) ПМЛ-1610-12А-42АС-(2з)-РТЛ1012-2(5,5-8,0А)-У2-А ВТМ00054446 | 6 478 ₽ на складе |
Еще 13 строк | |
... ВТМ (S) ПМЛ-1610-12А-36АС-(2з)-РТЛ1012- ... 2(5,5-8,0А)-У2-А ВТМ00054406 Далее Пускатель ВТМ - ВТМ00054406Пускатель ВТМ (S) ПМЛ-1610-12А-36АС-(2з)-РТЛ1012-2(5,5-8,0А)-У2-А ВТМ00054406 | 6 478 ₽ на складе |
... ВТМ (S) ПМЛ-1610-12А-36АС-(2з)-РТЛ1012- ... 2(5,5-8,0А)-У2-В ВТМ00054407 Далее Пускатель ВТМ - ВТМ00054407Пускатель ВТМ (S) ПМЛ-1610-12А-36АС-(2з)-РТЛ1012-2(5,5-8,0А)-У2-В ВТМ00054407 | 5 749 ₽ на складе |
... ВТМ (S) ПМЛ-1610-12А-380АС-(2з)-РТЛ1012- ... 2(5,5-8,0А)-У2-В ВТМ00054427 Далее Пускатель ВТМ - ВТМ00054427Пускатель ВТМ (S) ПМЛ-1610-12А-380АС-(2з)-РТЛ1012-2(5,5-8,0А)-У2-В ВТМ00054427 | 5 749 ₽ на складе |
... ВТМ (S) ПМЛ-1610-12А-220АС-(2з)-РТЛ1012- ... 2(5,5-8,0А)-У2-А ВТМ00054343 Далее Пускатель ВТМ - ВТМ00054343Пускатель ВТМ (S) ПМЛ-1610-12А-220АС-(2з)-РТЛ1012-2(5,5-8,0А)-У2-А ВТМ00054343 | 6 478 ₽ на складе |
... ВТМ (S) ПМЛ-1610-10А-42АС-(2з)-РТЛ1012- ... 2(5,5-8,0А)-У2-В ВТМ00052060 Далее Пускатель ВТМ - ВТМ00052060Пускатель ВТМ (S) ПМЛ-1610-10А-42АС-(2з)-РТЛ1012-2(5,5-8,0А)-У2-В ВТМ00052060 | 5 749 ₽ на складе |
... ВТМ (S) ПМЛ-1610-10А-220АС-(2з)-РТЛ1012- ... 2(5,5-8,0А)-У2-А ВТМ00052057 Далее Пускатель ВТМ - ВТМ00052057Пускатель ВТМ (S) ПМЛ-1610-10А-220АС-(2з)-РТЛ1012-2(5,5-8,0А)-У2-А ВТМ00052057 | 6 478 ₽ на складе |
... ВТМ (S) ПМЛ-1610-10А-42АС-(2з)-РТЛ1012- ... 2(5,5-8,0А)-У2-А ВТМ00052056 Далее Пускатель ВТМ - ВТМ00052056Пускатель ВТМ (S) ПМЛ-1610-10А-42АС-(2з)-РТЛ1012-2(5,5-8,0А)-У2-А ВТМ00052056 | 6 478 ₽ на складе |
... ВТМ (S) ПМЛ-1610-10А-24АС-(2з)-РТЛ1012- ... 2(5,5-8,0А)-У2-А ВТМ00052053 Далее Пускатель ВТМ - ВТМ00052053Пускатель ВТМ (S) ПМЛ-1610-10А-24АС-(2з)-РТЛ1012-2(5,5-8,0А)-У2-А ВТМ00052053 | 6 478 ₽ на складе |
... ВТМ (S) ПМЛ-1610-12А-42АС-(2з)-РТЛ1012- ... 2(5,5-8,0А)-У2-В ВТМ00054447 Далее Пускатель ВТМ - ВТМ00054447Пускатель ВТМ (S) ПМЛ-1610-12А-42АС-(2з)-РТЛ1012-2(5,5-8,0А)-У2-В ВТМ00054447 | 5 749 ₽ на складе |
... ВТМ (S) ПМЛ-1610-10А-24АС-(2з)-РТЛ1012- ... 2(5,5-8,0А)-У2-В ВТМ00052061 Далее Пускатель ВТМ - ВТМ00052061Пускатель ВТМ (S) ПМЛ-1610-10А-24АС-(2з)-РТЛ1012-2(5,5-8,0А)-У2-В ВТМ00052061 | 5 749 ₽ на складе |
... ВТМ (S) ПМЛ-1610-10А-110АС-(2з)-РТЛ1012- ... 2(5,5-8,0А)-У2-А ВТМ00052054 Далее Пускатель ВТМ - ВТМ00052054Пускатель ВТМ (S) ПМЛ-1610-10А-110АС-(2з)-РТЛ1012-2(5,5-8,0А)-У2-А ВТМ00052054 | 6 478 ₽ на складе |
... ВТМ (S) ПМЛ-1610-12А-110АС-(2з)-РТЛ1012- ... 2(5,5-8,0А)-У2-А ВТМ00054286 Далее Пускатель ВТМ - ВТМ00054286Пускатель ВТМ (S) ПМЛ-1610-12А-110АС-(2з)-РТЛ1012-2(5,5-8,0А)-У2-А ВТМ00054286 | 6 478 ₽ на складе |
... ВТМ (S) ПМЛ-1610-10А-36АС-(2з)-РТЛ1012- ... 2(5,5-8,0А)-У2-В ВТМ00052059 Далее Пускатель ВТМ - ВТМ00052059Пускатель ВТМ (S) ПМЛ-1610-10А-36АС-(2з)-РТЛ1012-2(5,5-8,0А)-У2-В ВТМ00052059 | 5 749 ₽ на складе |
28 AliExpress Китай Весь мир | |
474 ₽ от 21 дня | |
474 ₽ от 21 дня | |
54.0 ₽ от 10 шт 10 шт/лот от 21 дня | |
Еще 5 строк | |
324 ₽ от 10 шт 10 шт/лот от 21 дня | |
216 ₽ от 10 шт 10 шт/лот от 21 дня | |
Искать "1610-8" в других поисковых системах: Везде-РадиоЛоцман DataSheet.ru Google
USD | 92.1314 |
EUR | 98.7079 |
