3575.5 DOUBLE-LEVEL TERMINAL | Цена от 5 264 ₽ до 5 828 ₽ Медиана 5 546 ₽ В наличии 2 цены от 1 поставщика |
1 Akcel Китай Весь мир | |
Sensor Cables / Actuator Cables | запрос от 1 шт |
AC/DC CONVERTER 7.5V 35W | 1 388 ₽ от 1 шт 5-7 дней склад 8 шт |
Еще 3 цен: … 1 165 ₽ | |
1 310 ₽ от 10 шт 5-7 дней склад 8 шт | |
1 235 ₽ от 100 шт 5-7 дней склад 8 шт | |
1 165 ₽ от 1000 шт 5-7 дней склад 8 шт | |
Еще 50 строк | |
AC/DC CONVERTER 7.5V 35W | запрос от 1 шт |
Spring-cage type Din-Rail TB, connector method: Spring-cage/plug-in ... Далее WS2.5-SD-PESpring-cage type Din-Rail TB, connector method: Spring-cage/plug-in connector, Number of connectors: 2, Number of potentials: 1, Cross ... | запрос от 1 шт |
Spring-cage type Din-Rail TB, connector method: Spring-cage/plug-in ... Далее WS2.5-TW-TASpring-cage type Din-Rail TB, connector method: Spring-cage/plug-in connector, Rated voltage: 800 V, Rated current: 24 A, Number of ... | запрос от 1 шт |
Push-in Din-Rail TB, connector method: Push-in connector, Number of ... Далее DS1.5-QU-PEPush-in Din-Rail TB, connector method: Push-in connector, Number of connectors: 4, Number of potentials: 1, Cross section: 0.14 mm² - 1.5 mm ... | запрос от 1 шт |
Multi-level terminal block, connector method: Push-in connector, Rated ... Далее DS2.5-3L-PVMulti-level terminal block, connector method: Push-in connector, Rated voltage : 500 V,Rated current : 20 A, Number of connectors: 6, Number ... | запрос от 1 шт |
Disconnect terminal blocks, connector method: Push-in connector, Rated ... Далее DS2.5-MTDisconnect terminal blocks, connector method: Push-in connector, Rated voltage : 400 V,Rated current : 20 A, Number of connectors: 2, Number ... | запрос от 1 шт |
Diode terminal blocks, connector method: Push-in connector, Backward ... Далее DS2.5-TW-LD L-RDiode terminal blocks, connector method: Push-in connector, Backward voltage: 1300 V, Rated voltage : 800 V,Rated current : 1 A, Number of ... | запрос от 1 шт |
Diode terminal blocks, connector method: Push-in connector, Backward ... Далее DS2.5-LD R-LDiode terminal blocks, connector method: Push-in connector, Backward voltage: 1300 V, Rated voltage : 800 V,Rated current : 1 A, Number of ... | запрос от 1 шт |
Double-level terminal block, connector method: Push-in connector, ... Далее DSKK2.5-PVDouble-level terminal block, connector method: Push-in connector, Rated voltage : 500 V,Rated current : 22 A, Number of connectors: 4, ... | запрос от 1 шт |
Side ELM Term Blk w foot 5mm W (left) NS 32 or NS 35/7.5. PCBwidth: ... Далее 2959696Side ELM Term Blk w foot 5mm W (left) NS 32 or NS 35/7.5. PCBwidth: 107.5mm | 66.6 ₽ от 1 шт 5-7 дней склад 50 шт |
Еще 3 цен: … 55.9 ₽ | |
62.9 ₽ от 10 шт 5-7 дней склад 50 шт | |
59.3 ₽ от 100 шт 5-7 дней склад 50 шт | |
55.9 ₽ от 1000 шт 5-7 дней склад 50 шт | |
Mounting Hardware NS 35/7,5 UNPERF 2000MM/SLD PER M | запрос от 1 шт |
Mounting Hardware NS 35/7.5 PERF 1155 | запрос от 1 шт |
PLUG FUSE W/IND LIGHT 3.5-7.5MA | запрос от 1 шт |
Surge arrester consisting of base element with remote indicator ... Далее VAL-MS60/FMSurge arrester consisting of base element with remote indicator contact and protective connector with high-capacity varistor - for mounting ... | запрос от 1 шт |
Rail-mountable module with surge voltage coarse and fine protection ... Далее MT-RS485-TTLRail-mountable module with surge voltage coarse and fine protection for RS-485 interface - with TTL level - for mounting on NS 35/7.5 - ... | запрос от 1 шт |
PLC-RELAY with integrated switch (actuation: Manual) with screw ... Далее PLC-SC-S/HPLC-RELAY with integrated switch (actuation: Manual) with screw connection - for mounting on DIN rail NS 35/7.5 - input voltage ‰¤ 72 V DC | запрос от 1 шт |
Phoenix Contact CUT NS 35/7.5 PERF CLSD 24.25 | запрос от 1 шт |
2 AiPCBA Китай Весь мир | |
1 553 ₽ 2-7 дней отгрузка со склада в Китае склад 5 шт | |
1 537 ₽ 2-7 дней отгрузка со склада в Китае склад 40 шт | |
3 ChipWorker Китай Весь мир | |
1 676 ₽ 2-7 дней отгрузка со склада в Китае склад 5 шт | |
1 075 ₽ 2-7 дней отгрузка со склада в Китае склад 224 шт | |
1 567 ₽ 2-7 дней отгрузка со склада в Китае склад 32 шт | |
4 Utmel Китай Весь мир | |
AC/DC CONVERTER 7.5V 35W | запрос от 1 шт 5-7 дней склад 6304 шт |
AC/DC CONVERTER 7.5V 35W | 1 158 ₽ от 1 шт 5-7 дней склад 25 шт |
Еще 3 цен: … 972 ₽ | |
1 092 ₽ от 10 шт 5-7 дней склад 25 шт | |
1 030 ₽ от 100 шт 5-7 дней склад 25 шт | |
972 ₽ от 1000 шт 5-7 дней склад 25 шт | |
Mounting Hardware NS 35/7.5 PERF 1155 | 577 ₽ от 1 шт 5-7 дней склад 8243 шт |
Еще 3 цен: … 485 ₽ | |
544 ₽ от 10 шт 5-7 дней склад 8243 шт | |
514 ₽ от 100 шт 5-7 дней склад 8243 шт | |
485 ₽ от 1000 шт 5-7 дней склад 8243 шт | |
Еще 4 строки | |
Side element, right, with foot, width 5 mm, width 72 mm, for mounting ... Далее 2959353Side element, right, with foot, width 5 mm, width 72 mm, for mounting on NS 32 or NS 35/7.5 | 48.7 ₽ от 1 шт 5-7 дней склад 118 шт |
Еще 3 цен: … 40.9 ₽ | |
46.0 ₽ от 10 шт 5-7 дней склад 118 шт | |
43.4 ₽ от 100 шт 5-7 дней склад 118 шт | |
40.9 ₽ от 1000 шт 5-7 дней склад 118 шт | |
Side element, left, with foot, width 5 mm, length 72 mm, for mounting ... Далее 2959340Side element, left, with foot, width 5 mm, length 72 mm, for mounting on NS 32 or NS 35/7.5 | 48.7 ₽ от 1 шт 5-7 дней склад 83 шт |
46.0 ₽ от 10 шт 5-7 дней склад 83 шт | |
43.4 ₽ от 100 шт 5-7 дней склад 83 шт | |
40.9 ₽ от 1000 шт 5-7 дней склад 83 шт | |
Side ELM Term Blk w foot 5mm W (right) NS 32 or NS 35/7.5. PCBwidth: ... Далее 2959683Side ELM Term Blk w foot 5mm W (right) NS 32 or NS 35/7.5. PCBwidth: 107.5mm | 68.9 ₽ от 1 шт 5-7 дней склад 13759 шт |
Еще 3 цен: … 57.9 ₽ | |
65.0 ₽ от 10 шт 5-7 дней склад 13759 шт | |
61.3 ₽ от 100 шт 5-7 дней склад 13759 шт | |
57.9 ₽ от 1000 шт 5-7 дней склад 13759 шт | |
Side ELM Term Blk w foot 5mm W (left) NS 32 or NS 35/7.5. PCBwidth: ... Далее 2959696Side ELM Term Blk w foot 5mm W (left) NS 32 or NS 35/7.5. PCBwidth: 107.5mm | 68.9 ₽ от 1 шт 5-7 дней склад 50 шт |
65.0 ₽ от 10 шт 5-7 дней склад 50 шт | |
61.3 ₽ от 100 шт 5-7 дней склад 50 шт | |
57.9 ₽ от 1000 шт 5-7 дней склад 50 шт | |
5 ТМ Электроникс Санкт-Петербург Россия | |
Наконечник: плоский; 5,2мм; 0,8мм; "мама"; THT; латунь; ... Далее 3575Наконечник: плоский; 5,2мм; 0,8мм; "мама"; THT; латунь; луженые | 79.8 ₽ от 3 шт 5-10 дней склад 488 шт |
Еще 3 цен: … 51.6 ₽ | |
66.2 ₽ от 10 шт 5-10 дней склад 488 шт | |
58.8 ₽ от 50 шт 5-10 дней склад 488 шт | |
51.6 ₽ от 100 шт 5-10 дней склад 488 шт | |
Разъем: краевой; RAST 2.5; вилка; "мама"; угловой 90°; ... Далее 3575 02 K04M09Разъем: краевой; RAST 2.5; вилка; "мама"; угловой 90°; Glow-Wire | 150 ₽ от 2 шт 5-10 дней склад 7031 шт |
Еще 3 цен: … 105 ₽ | |
135 ₽ от 20 шт 5-10 дней склад 7031 шт | |
120 ₽ от 100 шт 5-10 дней склад 7031 шт | |
105 ₽ от 500 шт 5-10 дней склад 7031 шт | |
Блок питания: импульсный; без корпуса; 35,25Вт; 120÷370ВDC; OUT: 1 | 3 191 ₽ от 1 шт 5-10 дней склад 30 шт |
Еще 3 цен: … 2 818 ₽ | |
3 031 ₽ от 5 шт 5-10 дней склад 30 шт | |
2 898 ₽ от 10 шт 5-10 дней склад 30 шт | |
2 818 ₽ от 20 шт 5-10 дней склад 30 шт | |
Еще 3 строки | |
Соединительный кабель; M8; PIN: 3; угловой; 5м; вилка; 4А; -30÷90° ... Далее RKMWVS 3-357/5 MСоединительный кабель; M8; PIN: 3; угловой; 5м; вилка; 4А; -30÷90°C | 3 592 ₽ от 1 шт 5-10 дней склад 17 шт |
DIN rail; steel; W: 35mm; L: 205mm; for enclosures; PH-0899349 | 4 217 ₽ от 1 шт 5-10 дней склад 2 шт |
Еще 2 цен: … 3 709 ₽ | |
3 962 ₽ от 3 шт 5-10 дней склад 2 шт | |
3 709 ₽ от 5 шт 5-10 дней склад 2 шт | |
NTC thermistor; 10kΩ; THT; 3575K; -80÷135°C; 38mm; ±0,5° ... Далее KW103G2NTC thermistor; 10kΩ; THT; 3575K; -80÷135°C; 38mm; ±0,5°C | 816 ₽ от 1 шт 5-10 дней склад 223 шт |
Еще 4 цен: … 452 ₽ | |
665 ₽ от 10 шт 5-10 дней склад 223 шт | |
540 ₽ от 25 шт 5-10 дней склад 223 шт | |
502 ₽ от 50 шт 5-10 дней склад 223 шт | |
452 ₽ от 250 шт 5-10 дней склад 223 шт | |
6 Онлайн Компоненты Москва Россия | |
Аксессуар, NS 35/7.5, NS 35/15 DIN Rails, End Clamp, CLIPLINE HV ... Далее CLIPFIX 35-5 V0Аксессуар, NS 35/7.5, NS 35/15 DIN Rails, End Clamp, CLIPLINE HV Series | 178 ₽ от 1 шт 5-12 дней склад 109 шт |
Еще 4 цен: … 164 ₽ | |
175 ₽ от 10 шт 5-12 дней склад 109 шт | |
171 ₽ от 25 шт 5-12 дней склад 109 шт | |
168 ₽ от 50 шт 5-12 дней склад 109 шт | |
164 ₽ от 100 шт 5-12 дней склад 109 шт | |
Аксессуар разъема, Основание и опора, NS 32, NS 35/7.5 DIN-рейкой, ... Далее 2955564 UM-BEFEАксессуар разъема, Основание и опора, NS 32, NS 35/7.5 DIN-рейкой, Серия UM | 1 269 ₽ от 1 шт 5-12 дней склад 436 шт |
Еще 5 цен: … 1 141 ₽ | |
1 244 ₽ от 10 шт 5-12 дней склад 436 шт | |
1 219 ₽ от 100 шт 5-12 дней склад 436 шт | |
1 194 ₽ от 250 шт 5-12 дней склад 436 шт | |
1 166 ₽ от 500 шт 5-12 дней склад 436 шт | |
1 141 ₽ от 1000 шт 5-12 дней склад 436 шт | |
Концевой зажим, для использования с DiN-рейками NS 32 или NS 35/7.5, ... Далее E/UKКонцевой зажим, для использования с DiN-рейками NS 32 или NS 35/7.5, серого цвета, Евро/Английский | 239 ₽ от 1 шт 5-12 дней склад 2143 шт |
Еще 5 цен: … 192 ₽ | |
209 ₽ от 10 шт 5-12 дней склад 2143 шт | |
205 ₽ от 100 шт 5-12 дней склад 2143 шт | |
200 ₽ от 500 шт 5-12 дней склад 2143 шт | |
196 ₽ от 1000 шт 5-12 дней склад 2143 шт | |
192 ₽ от 2500 шт 5-12 дней склад 2143 шт | |
Еще 1 строка | |
Аксессуар разъема, Торцевая часть с защелкой, NS 35/7.5 NS 35/15, ... Далее 3022276Аксессуар разъема, Торцевая часть с защелкой, NS 35/7.5 NS 35/15, Серия CLIPFIX | 189 ₽ от 1 шт 5-12 дней склад 2404 шт |
Еще 5 цен: … 170 ₽ | |
185 ₽ от 10 шт 5-12 дней склад 2404 шт | |
182 ₽ от 100 шт 5-12 дней склад 2404 шт | |
178 ₽ от 500 шт 5-12 дней склад 2404 шт | |
174 ₽ от 1000 шт 5-12 дней склад 2404 шт | |
170 ₽ от 2500 шт 5-12 дней склад 2404 шт | |
7 ЗУМ-СМД Москва Россия Только юр.лица Безнал. расчет Заказ от 5000 руб. Строка от 600 руб. | |
Разъемы / Держатели светодиодов LDH 3.5mm 7.50mm | 0.06 ₽ от 600 ₽ склад 4380 шт |
8 ЭИК Санкт-Петербург Россия | |
DOUBLE-LEVEL TERMINAL | 5 828 ₽ от 1 шт 21-42 дня склад 7 шт |
5 264 ₽ от 3 шт 21-42 дня склад 7 шт | |
AC/DC CONVERTER 7.5V 35W | 2 710 ₽ от 1 шт 21-42 дня склад 30 шт |
Еще 3 цен: … 2 394 ₽ | |
2 574 ₽ от 5 шт 21-42 дня склад 30 шт | |
2 461 ₽ от 10 шт 21-42 дня склад 30 шт | |
2 394 ₽ от 20 шт 21-42 дня склад 30 шт | |
9 Триема Воронеж Россия Филиалы: Москва Белгород Курск Липецк Орел Тула | |
675 ₽ Доставка: есть Самовывоз: есть на складе | |
Твердосплавное свёрло с цилиндрическим хвостовиком HE 5,5 мм или дюймы ... Далее Сверло (122773 5, 5)Твердосплавное свёрло с цилиндрическим хвостовиком HE 5,5 мм или дюймы. Допуск на номинальный ? - m7. Длина стружечной канавки - 44 мм. ... | 3 856 ₽ Доставка: есть Самовывоз: есть на складе |
Сверло HSS-E FS 17,5 мм. Угол при вершине - 135 градусов. ... Далее Сверло (113020 17, 5)Сверло HSS-E FS 17,5 мм. Угол при вершине - 135 градусов. рекомендуемая максимальная глубина сверления - 35.75 мм. Число режущих кромок - 2. ... | 8 235 ₽ Доставка: есть Самовывоз: есть на складе |
Еще 15 строк | |
Спиральные сверла HSS 17,5 мм. Угол при вершине - 130 градусов. Допуск ... Далее Сверло (113005 17, 5)Спиральные сверла HSS 17,5 мм. Угол при вершине - 130 градусов. Допуск на номинальный ? - h8. ? хвостовика - 18.5 мм. Длина стружечной ... | 3 312 ₽ Доставка: есть Самовывоз: есть на складе |
SUNNY Rs90 (SUNNY16)(краска) | 12.0 ₽ Доставка: есть Самовывоз: есть на складе |
2.00 ₽ Доставка: есть Самовывоз: есть на складе | |
490 ₽ Доставка: есть Самовывоз: есть на складе | |
9.00 ₽ Доставка: есть Самовывоз: есть на складе | |
Монтажный комплект для модулей gesis FLEX, размеры 40x20 см | 8 143 ₽ Доставка: есть Самовывоз: есть на складе |
Монтажный комплект для модулей gesis FLEX, размеры 100x20 см | 12 904 ₽ Доставка: есть Самовывоз: есть на складе |
273 ₽ Доставка: есть Самовывоз: есть на складе | |
681 ₽ Доставка: есть Самовывоз: есть на складе | |
МОНТАЖНАЯ РЕЙКА 0804278 | 2 988 ₽ Доставка: есть Самовывоз: есть на складе |
DIN-рейка, G-рейка | 790 ₽ Доставка: есть Самовывоз: есть на складе |
DIN-рейка, G-рейка | 316 ₽ Доставка: есть Самовывоз: есть на складе |
154 ₽ Доставка: есть Самовывоз: есть на складе | |
3,575.25 | 4 682 ₽ Доставка: есть Самовывоз: есть на складе |
Быстроразъемные.Вес брутто: 35.75Транспортная упаковка: размер/кол-во: ... Далее FQ24-26pin ZKБыстроразъемные.Вес брутто: 35.75Транспортная упаковка: размер/кол-во: 42*30.5*26/200Номинальный ток: 3 АТип: FQ24Номинальное напряжение: ... | 484 ₽ Доставка: есть Самовывоз: есть на складе |
10 Industrial Module Москва Россия | |
Модуль Phoenix Contact | запрос 7-28 дней на складе |
Еще 62 строки | |
QIDR353505 QLINE DIN RAIL TS35/7.5 400W | 498 ₽ 7-28 дней на складе |
QIDR352505 QLINE DIN RAIL TS35/7.5 300W | 299 ₽ 7-28 дней на складе |
OMEGA DIN RAIL 35-7,5 175L (4X) (Мин. заказ 4 шт) | 1 294 ₽ 7-28 дней на складе |
OMEGA DIN RAIL 35-7,5 125L (4X) (Мин. заказ 4 шт) | 1 195 ₽ 7-28 дней на складе |
OMEGA DIN RAIL 35-7,5 275L (4X) (Мин. заказ 4 шт) | 1 693 ₽ 7-28 дней на складе |
OMEGA DIN RAIL 35-7,5 475L (10X) (Мин. заказ 10 шт) | 4 679 ₽ 7-28 дней на складе |
OMEGA DIN RAIL 35-7,5 375L (10X) (Мин. заказ 10 шт) | 4 281 ₽ 7-28 дней на складе |
OMEGA DIN RAIL 35-7,5 575L (10X) (Мин. заказ 10 шт) | 5 078 ₽ 7-28 дней на складе |
OMEGA DIN RAIL 35-7,5 575L (4X) (Мин. заказ 4 шт) | 2 190 ₽ 7-28 дней на складе |
OMEGA DIN RAIL 35-7,5 375L (4X) (Мин. заказ 4 шт) | 1 892 ₽ 7-28 дней на складе |
OMEGA DIN RAIL 35-7,5 175L (10X) (Мин. заказ 10 шт) | 2 987 ₽ 7-28 дней на складе |
OMEGA DIN RAIL 35-7,5 275L (10X) (Мин. заказ 10 шт) | 3 883 ₽ 7-28 дней на складе |
OMEGA DIN RAIL 35-7,5 475L (4X) (Мин. заказ 4 шт) | 2 091 ₽ 7-28 дней на складе |
QIDR351505 QLINE DIN RAIL TS35/7.5 200W | 199 ₽ 7-28 дней на складе |
OMEGA DIN RAIL 35-7,5 125L (10X) (Мин. заказ 10 шт) | 2 688 ₽ 7-28 дней на складе |
11 МосЧип Москва Россия | |
RAST-2.5-Power-Steckverbinder, Raster 5,0 mm | запрос 7-14 дней |
Линейные и импульсные источники питания 35.25W 7.5V 4.7A | запрос 7-14 дней |
Оборудование для монтажа NS 35/7.5 PERFORATED-8 | запрос 7-14 дней |
Еще 1 строка | |
РЧ-соединители ACC NA INS RING STG 3.5/75DS | запрос 7-14 дней |
12 Десси Москва Россия | |
Проходные клеммы, Тип подключения:Винтовые зажимы, Сечение:0,2 мм?-6 ... Далее Клеммник на DIN-рейку 3004362 UK 5 NПроходные клеммы, Тип подключения:Винтовые зажимы, Сечение:0,2 мм?-6 мм?, AWG24-10, Ширина:6,2 мм, Цвет:cерый, Тип монтажа:NS 35/7,5,NS 35/ ... | 108 ₽ |
Проходные клеммы, Тип подключения:Пружинный зажим, Пружинный зажим, ... Далее Клеммник на DIN-рейку 3031254 ST 2.5-TWIN BUПроходные клеммы, Тип подключения:Пружинный зажим, Пружинный зажим, Сечение:0,08 мм?-4 мм?, AWG28-12, Ширина:5,2 мм, Цвет:синий, Тип монтажа ... | 147 ₽ |
Название 2775210 UDK 4-MTK-P/P Бренд PHOENIX Описание Проходные клеммы ... Далее Клеммник на DIN-рейку 2775210 UDK 4-MTK-P/PНазвание 2775210 UDK 4-MTK-P/P Бренд PHOENIX Описание Проходные клеммы, Тип подключения:Винтовые зажимы, Сечение:0,2 мм?-6 мм?, AWG:24-12, ... | 456 ₽ |
13 ЧипСити Москва Россия | |
Quick-fit end bracket, inflammability class V0 according to UL 94, for ... Далее CLIPFIX 35-5 V0Quick-fit end bracket, inflammability class V0 according to UL 94, for DIN rail NS 35/7,5 or NS 35/15, can be marked with UC-TM 5, UC-TMF 5, ... | 93.7 ₽ 3-7 дней склад 688 шт |
Fuse modular terminal block, number of positions: 1, connection method ... Далее UK 5-HESILED 24 NFuse modular terminal block, number of positions: 1, connection method: Screw connection, cross section: 0.2mm²- 6mm², AWG: 24 - 10, nominal ... | 1 441 ₽ 3-7 дней склад 197 шт |
Fuse modular terminal block, number of positions: 1, connection method ... Далее UK 5-HESI NFuse modular terminal block, number of positions: 1, connection method: Screw connection, cross section: 0.2mm²- 6mm², AWG: 24 - 10, nominal ... | 914 ₽ 3-7 дней склад 163 шт |
Еще 137 строк | |
Fuse modular terminal block, number of positions: 1, connection method ... Далее UK 5-HESILED 60 NFuse modular terminal block, number of positions: 1, connection method: Screw connection, cross section: 0.2mm²- 6mm², AWG: 24 - 10, nominal ... | 1 253 ₽ 3-7 дней склад 1128 шт |
Knife disconnect terminal block, With test socket screws for insertion ... Далее UKK 5-MTK-P/PKnife disconnect terminal block, With test socket screws for insertion of test plugs, connection method: Screw connection, cross section: 0. ... | 1 379 ₽ 3-7 дней склад 383 шт |
Knife disconnect terminal block, With test socket screws for insertion ... Далее UKK 5-MTK-P/P-DIO/OL-UKnife disconnect terminal block, With test socket screws for insertion of test plugs, connection method: Screw connection, cross section: 0. ... | 2 347 ₽ 3-7 дней склад 404 шт |
Feed-through terminal block, With test socket screws for insertion of ... Далее MTKD-P/PFeed-through terminal block, With test socket screws for insertion of test plugs, connection method: Screw connection, number of connections ... | 510 ₽ 3-7 дней склад 1018 шт |
Fuse modular terminal block, connection method: Push-in connection, ... Далее PT 4-HESI (5X20)Fuse modular terminal block, connection method: Push-in connection, cross section: 0.2mm²- 6mm², AWG: 24 - 10, nominal current: 6.3A, nom. ... | 649 ₽ 3-7 дней склад 315 шт |
Feed-through terminal block, Connection method: Screw connection, ... Далее MTKDFeed-through terminal block, Connection method: Screw connection, Number of positions: 1, Cross section: 0.2mm² - 4mm², AWG: 24 - 12, Width: ... | 395 ₽ 3-7 дней склад 992 шт |
PLC-INTERFACE, consisting of PLC-BPT.../21 basic terminal block with ... Далее PLC-RPT-48DC/21AUPLC-INTERFACE, consisting of PLC-BPT.../21 basic terminal block with push-in connection and plug-in miniature relay with multi-layer gold ... | 2 939 ₽ 3-7 дней склад 334 шт |
Ground modular terminal block, connection method: Push-in connection, ... Далее PT 4-PEGround modular terminal block, connection method: Push-in connection, number of connections: 2, cross section:0.2mm² - 6mm², AWG: 24 - 10, ... | 501 ₽ 3-7 дней склад 404 шт |
Component terminal block, With test socket screws for insertion of ... Далее UT 4-MTD-DIO/L-R-P/PComponent terminal block, With test socket screws for insertion of test plugs, connection method: Screw connection, number of connections: 2 ... | 502 ₽ 3-7 дней склад 1111 шт |
Feed-through terminal block, connection method: Push-in connection, ... Далее PT 6-QUATTRO BUFeed-through terminal block, connection method: Push-in connection, number of connections: 4, cross section:0.5mm² - 10mm², AWG: 20 - 8, ... | 492 ₽ 3-7 дней склад 924 шт |
6.2mm PLC basic terminal block for TTL signal with screw connection, ... Далее PLC-BSC-TTL/16.2mm PLC basic terminal block for TTL signal with screw connection, without relay or solid-state relay, for mounting on DIN rail NS 35/7,5, ... | 3 443 ₽ 3-7 дней склад 1068 шт |
Side element with foot, 5mm wide (right), for mounting on NS 32 or NS ... Далее UM108-SEFE/R BKSide element with foot, 5mm wide (right), for mounting on NS 32 or NS 35/7.5. PCB width: 107.5mm | 153 ₽ 3-7 дней склад 996 шт |
Component terminal block, with integrated diode, connection method: ... Далее ST 4-DIO 1N 5408/R-LComponent terminal block, with integrated diode, connection method: Spring-cage connection, cross section: 0.08mm² - 6mm², AWG: 28 - 10, ... | 514 ₽ 3-7 дней склад 1229 шт |
Component terminal block, with integrated diode 1N5408, connection ... Далее PT 4-DIO 1N 5408/R-LComponent terminal block, with integrated diode 1N5408, connection method: Push-in connection, cross section: 0.2mm² - 6mm², AWG: 24 - 10, ... | 535 ₽ 3-7 дней склад 1238 шт |
Side element, left, with foot, width: 5mm, length: 72mm, for mounting ... Далее UM 72-SEPEF/LSide element, left, with foot, width: 5mm, length: 72mm, for mounting on NS 32 or NS 35/7.5, with PE contact to the DIN rail | 1 253 ₽ 3-7 дней склад 1060 шт |
Side element, left, with foot, width: 5mm, length: 72mm, for mounting ... Далее UM 72-SEFE/L BKSide element, left, with foot, width: 5mm, length: 72mm, for mounting on NS 32 or NS 35/7.5 | 113 ₽ 3-7 дней склад 1034 шт |
Side element, left, with foot, width 5mm, length 72mm, for mounting on ... Далее UM 72-SEFE/LSide element, left, with foot, width 5mm, length 72mm, for mounting on NS 32 or NS 35/7.5 | 112 ₽ 3-7 дней склад 1089 шт |
14 Оптулс Москва Россия | |
Проходные клеммы - PT 2,5 OG - 3212329 Phoenix contact Проходные ... Далее Проходные клеммы - PT 2, 5 OG - 3212329 Phoenix contactПроходные клеммы - PT 2,5 OG - 3212329 Phoenix contact Проходные клеммы, тип соединения: Push-in, поперечное сечение: 0,08 мм? - 4 мм?, ... | 108 ₽ Розница, Скидки для Дилеров - |
Проходные клеммы - PTS 2,5 - 3211799 Phoenix contact Проходные клеммы, ... Далее Проходные клеммы - PTS 2, 5 - 3211799 Phoenix contactПроходные клеммы - PTS 2,5 - 3211799 Phoenix contact Проходные клеммы, Тип подключения: Зажимы Push-in, Сечение: 0,14 мм? - 4 мм?, AWG: 26 ... | 107 ₽ Розница, Скидки для Дилеров - |
Двухъярусные клеммы - PTTB 1,5/S - 3208511 Phoenix contact ... Далее Двухъярусные клеммы - PTTB 1, 5/S - 3208511 Phoenix contactДвухъярусные клеммы - PTTB 1,5/S - 3208511 Phoenix contact Двухъярусные клеммы, Сечение: 0,14 мм? - 1,5 мм?, AWG: 26 - 14, Тип подключения: ... | 176 ₽ Розница, Скидки для Дилеров - |
Еще 639 строк | |
Двухъярусные клеммы - PTTB 1,5/S BU - 3208524 Phoenix contact ... Далее Двухъярусные клеммы - PTTB 1, 5/S BU - 3208524 Phoenix contactДвухъярусные клеммы - PTTB 1,5/S BU - 3208524 Phoenix contact Двухъярусные клеммы, Сечение: 0,14 мм? - 1,5 мм?, AWG: 26 - 14, Тип ... | 171 ₽ Розница, Скидки для Дилеров - |
Двухъярусные клеммы - PTTB 1,5/S-L/N - 3208544 Phoenix contact ... Далее Двухъярусные клеммы - PTTB 1, 5/S-L/N - 3208544 Phoenix contactДвухъярусные клеммы - PTTB 1,5/S-L/N - 3208544 Phoenix contact Двухъярусные клеммы, Сечение: 0,14 мм? - 1,5 мм?, AWG: 26 - 14, Тип ... | 184 ₽ Розница, Скидки для Дилеров - |
Проходные клеммы - PT 1,5/S - 3208100 Phoenix contact Проходные клеммы ... Далее Проходные клеммы - PT 1, 5/S - 3208100 Phoenix contactПроходные клеммы - PT 1,5/S - 3208100 Phoenix contact Проходные клеммы, Тип подключения: Зажимы Push-in, Сечение: 0,14 мм? - 1,5 мм?, AWG: ... | 73.3 ₽ Розница, Скидки для Дилеров - |
Проходные клеммы - PT 1,5/S BU - 3208126 Phoenix contact Проходные ... Далее Проходные клеммы - PT 1, 5/S BU - 3208126 Phoenix contactПроходные клеммы - PT 1,5/S BU - 3208126 Phoenix contact Проходные клеммы, Тип подключения: Зажимы Push-in, Сечение: 0,14 мм? - 1,5 мм?, AWG ... | 91.4 ₽ Розница, Скидки для Дилеров - |
Проходные клеммы - PTS 1,5/S - 3214547 Phoenix contact Проходные ... Далее Проходные клеммы - PTS 1, 5/S - 3214547 Phoenix contactПроходные клеммы - PTS 1,5/S - 3214547 Phoenix contact Проходные клеммы, Тип подключения: Зажимы Push-in, Сечение: 0,14 мм? - 1,5 мм?, AWG: ... | 93.8 ₽ Розница, Скидки для Дилеров - |
Клеммный блок со встр. элементами - ST 2, 5-R 15K - 3035027 Phoenix contact Phoenix Contact 28 Фев 2024 17:35 Клеммный блок со встр. элементами - ST 2,5-R 15K - 3035027 Phoenix ... Далее Клеммный блок со встр. элементами - ST 2, 5-R 15K - 3035027 Phoenix contactКлеммный блок со встр. элементами - ST 2,5-R 15K - 3035027 Phoenix contact Клеммный блок со встр. элементами , Тип подключения: Пружинный ... | 628 ₽ Розница, Скидки для Дилеров - |
Клеммный блок со встр. элементами - ST 2, 5-QUATTRO-DIO/L-R OG - 3028937 Phoenix contact Phoenix Contact 28 Фев 2024 17:35 Клеммный блок со встр. элементами - ST 2,5-QUATTRO-DIO/L-R OG - ... Далее Клеммный блок со встр. элементами - ST 2, 5-QUATTRO-DIO/L-R OG - 3028937 Phoenix contactКлеммный блок со встр. элементами - ST 2,5-QUATTRO-DIO/L-R OG - 3028937 Phoenix contact Клеммный блок со встр. элементами , Тип подключения ... | 464 ₽ Розница, Скидки для Дилеров - |
Проходные клеммы - PT 2,5-TWIN OG - 3211210 Phoenix contact Проходные ... Далее Проходные клеммы - PT 2, 5-TWIN OG - 3211210 Phoenix contactПроходные клеммы - PT 2,5-TWIN OG - 3211210 Phoenix contact Проходные клеммы, Тип подключения: Зажимы Push-in, Сечение: 0,14 мм? - 4 мм?, ... | 108 ₽ Розница, Скидки для Дилеров - |
Проходные клеммы - PT 2,5-TWIN RD - 3211223 Phoenix contact Проходные ... Далее Проходные клеммы - PT 2, 5-TWIN RD - 3211223 Phoenix contactПроходные клеммы - PT 2,5-TWIN RD - 3211223 Phoenix contact Проходные клеммы, Тип подключения: Зажимы Push-in, Сечение: 0,14 мм? - 4 мм?, ... | 127 ₽ Розница, Скидки для Дилеров - |
Проходные клеммы - PTS 2,5-QUATTRO - 3211993 Phoenix contact Проходные ... Далее Проходные клеммы - PTS 2, 5-QUATTRO - 3211993 Phoenix contactПроходные клеммы - PTS 2,5-QUATTRO - 3211993 Phoenix contact Проходные клеммы, Тип подключения: Зажимы Push-in, Сечение: 0,14 мм? - 4 мм?, ... | 155 ₽ Розница, Скидки для Дилеров - |
Проходные клеммы - PTS 2,5-QUATTRO BU - 3212002 Phoenix contact ... Далее Проходные клеммы - PTS 2, 5-QUATTRO BU - 3212002 Phoenix contactПроходные клеммы - PTS 2,5-QUATTRO BU - 3212002 Phoenix contact Проходные клеммы, Тип подключения: Зажимы Push-in, Сечение: 0,14 мм? - 4 мм ... | 172 ₽ Розница, Скидки для Дилеров - |
Монтажные многоярусные клеммы - PTI 2, 5-PE/L/N - 3213950 Phoenix contact Phoenix Contact 28 Фев 2024 17:35 Монтажные многоярусные клеммы - PTI 2,5-PE/L/N - 3213950 Phoenix ... Далее Монтажные многоярусные клеммы - PTI 2, 5-PE/L/N - 3213950 Phoenix contactМонтажные многоярусные клеммы - PTI 2,5-PE/L/N - 3213950 Phoenix contact Монтажные многоярусные клеммы, Зажимы Push-in, Сечение: 0,14 мм? - ... | 302 ₽ Розница, Скидки для Дилеров - |
Проходная мини-клемма - MSB 2,5-NS 35-PE - 3244148 Phoenix contact ... Далее Проходная мини-клемма - MSB 2, 5-NS 35-PE - 3244148 Phoenix contactПроходная мини-клемма - MSB 2,5-NS 35-PE - 3244148 Phoenix contact Проходная мини-клемма, Тип подключения: Пружинный зажим, Сечение: 0,08 мм ... | 202 ₽ Розница, Скидки для Дилеров - |
Многоярусный клеммный модуль - ST 2, 5-PE/2PV - 3038833 Phoenix contact Phoenix Contact 28 Фев 2024 17:35 Многоярусный клеммный модуль - ST 2,5-PE/2PV - 3038833 Phoenix contact ... Далее Многоярусный клеммный модуль - ST 2, 5-PE/2PV - 3038833 Phoenix contactМногоярусный клеммный модуль - ST 2,5-PE/2PV - 3038833 Phoenix contact Многоярусный клеммный модуль, Сечение: 0,08 мм? - 4 мм?, AWG: 28 - 12 ... | 790 ₽ Розница, Скидки для Дилеров - |
Клеммный блок со встр. элементами - ST 2, 5-TWIN-R1K 0, 6W - 3038354 Phoenix contact Phoenix Contact 28 Фев 2024 17:35 Клеммный блок со встр. элементами - ST 2,5-TWIN-R1K 0,6W - 3038354 ... Далее Клеммный блок со встр. элементами - ST 2, 5-TWIN-R1K 0, 6W - 3038354 Phoenix contactКлеммный блок со встр. элементами - ST 2,5-TWIN-R1K 0,6W - 3038354 Phoenix contact Клеммный блок со встр. элементами , Тип подключения: ... | 430 ₽ Розница, Скидки для Дилеров - |
Клеммный блок со встр. элементами - ST 2, 5-TWIN-DIO/L-R RD - 3037847 Phoenix contact Phoenix Contact 28 Фев 2024 17:35 Клеммный блок со встр. элементами - ST 2,5-TWIN-DIO/L-R RD - 3037847 ... Далее Клеммный блок со встр. элементами - ST 2, 5-TWIN-DIO/L-R RD - 3037847 Phoenix contactКлеммный блок со встр. элементами - ST 2,5-TWIN-DIO/L-R RD - 3037847 Phoenix contact Клеммный блок со встр. элементами , Тип подключения: ... | 440 ₽ Розница, Скидки для Дилеров - |
Клеммный блок со встр. элементами - STTB 2, 5/2P-DIO/O-U - 3040753 Phoenix contact Phoenix Contact 28 Фев 2024 17:35 Клеммный блок со встр. элементами - STTB 2,5/2P-DIO/O-U - 3040753 ... Далее Клеммный блок со встр. элементами - STTB 2, 5/2P-DIO/O-U - 3040753 Phoenix contactКлеммный блок со встр. элементами - STTB 2,5/2P-DIO/O-U - 3040753 Phoenix contact Клеммный блок со встр. элементами , Сечение: 0,08 мм? - 4 ... | 525 ₽ Розница, Скидки для Дилеров - |
15 Берёзка Электронные Компоненты Москва Россия Заказ от 3000 руб. Строка от 100 руб. | |
3.5mm 7.50mm | 1.02 ₽ розница 2-3 рабочих дня склад 14400 шт |
Еще 3 цен: … 0.68 ₽ | |
0.72 ₽ мелкий опт 2-3 рабочих дня склад 14400 шт | |
0.70 ₽ средний опт 2-3 рабочих дня склад 14400 шт | |
0.68 ₽ крупный опт 2-3 рабочих дня склад 14400 шт | |
16 Контест Москва Россия | |
SPL-35/7, 5 25 Апр 2024 02:08 Отделяющая индуктивность | 18 839 ₽ |
17 ЭлектроПласт Санкт-Петербург Россия | |
Комплектующие для клеммных колодок NS 35/7.5 PERF 955MM | запрос 7-14 дней |
Оборудование для монтажа NS35/7.5 PERF 1METER | запрос 7-14 дней |
18 LifeElectronics Санкт-Петербург Россия | |
Lowpass Filter | запрос 7-14 дней |
Комплектующие для клеммных колодок NS 35/7.5 CAP | запрос 7-14 дней |
Еще 1 строка | |
19 TradeElectronics Москва Россия | |
NS35/7.5 25 Апр 2024 02:59 | запрос 7-14 дней |
Автомобильные разъемы SICMA2 1.5 M .35-.75MM2 FIAT | запрос 7-14 дней |
20 Стандарт СИЗ Москва Россия Только юр.лица Безнал. расчет Заказ от 5000 руб. Строка от 400 руб. | |
3.5mm 7.50mm | 0.25 ₽ от 5000 ₽ |
421 ₽ от 5000 ₽ | |
389 ₽ от 5000 ₽ | |
21 ЭлектроПласт- Екатеринбург Екатеринбург Россия | |
SP3 Series Mini-SIP Passive Delay Modules | запрос 7-14 дней |
Клеммные колодки для DIN-рейки For Mounting on NS 35/7.5 DIN Rail | запрос 7-14 дней |
22 Океан Электроники Санкт-Петербург Россия | |
TS35/7, 5 25 Апр 2024 02:59 Thermal Sensors MOXIE | запрос 7-14 дней |
23 ICdarom.ru Москва Россия Заказ от 3000 руб. Строка от 100 руб. | |
3.5mm 7.50mm | 1.02 ₽ розница 2-3 рабочих дня склад 14700 шт |
Еще 3 цен: … 0.67 ₽ | |
0.71 ₽ мелкий опт 2-3 рабочих дня склад 14700 шт | |
0.68 ₽ средний опт 2-3 рабочих дня склад 14700 шт | |
0.67 ₽ крупный опт 2-3 рабочих дня склад 14700 шт | |
24 Элитан Ижевск Россия Безнал. расчет Филиалы: Москва Санкт-Петербург Екатеринбург Новосибирск | |
2 960 ₽ | |
3 107 ₽ | |
25 T-electron Раменское, Московская обл. Россия и страны СНГ | |
EPS357.5 20 Ноя 2023 00:56 | 1 413 ₽ склад 69 шт |
PS357.5 20 Ноя 2023 00:56 | 2 364 ₽ склад 3 шт |
0.53 ₽ по запросу | |
Еще 13 строк | |
745 ₽ склад 626 шт | |
915 ₽ склад 510 шт | |
FIX3.57.5 20 Ноя 2023 00:56 | 3.49 ₽ склад 3400 шт |
PS-35-7.5 20 Ноя 2023 00:56 | 132 745 ₽ по запросу |
запрос да | |
запрос да | |
запрос да | |
запрос да | |
запрос да | |
582 ₽ склад 41 шт | |
649 ₽ склад 17 шт | |
664 ₽ склад 1 шт | |
719 ₽ склад 13 шт | |
26 РЕФРО Москва Россия | |
Стеллаж прямой сплошной Assum СТП-С-15/5 (СТПЭ-15/5)Модель: СТПЭ-15/ ... Далее Стеллаж прямой сплошной Assum СТП-С-15/5 (СТПЭ-15/5)Стеллаж прямой сплошной Assum СТП-С-15/5 (СТПЭ-15/5)Модель: СТПЭ-15/5Страна: РоссияВес без упаковки, кг: 35,75Ширина, мм: 1 500Глубина, мм: ... | 16 064 ₽ на складе |
27 Кремний Санкт-Петербург Россия и страны СНГ | |
EPS-35-7.5 25 Апр 2024 02:59 | запрос 7-14 дней |
28 ТаймЧипс Санкт-Петербург Россия | |
Комплектующие для клеммных колодок NS 35/7.5 5.2X25 P. WH | запрос 7-14 дней |
Формирование сигнала 942.5 1842.5/ 35_75MHz Filter | запрос 7-14 дней |
Еще 4 строки | |
Автомобильные разъемы SICMA2 1.5 F .35-.75MM2 FIAT | запрос 7-14 дней |
Оборудование для монтажа NS35/7.5 UNPERF 1M | запрос 7-14 дней |
Комплектующие для клеммных колодок NS 35/7,5-AL UNPERF 2000MM | запрос 7-14 дней |
WT30-FT001 25 Апр 2024 02:59 DIN RAIL MNT BRKT FOR TH35-7.5 | запрос 7-14 дней |
29 ВсеИнструменты.ру Москва Россия | |
DIN-рейка CHINT L1000 TH35-7.5 оцинк. 570003 | 184 ₽ на складе |
Ушковый хомут OETIKER 54.3-57.5 мм, ширина 9 мм, нерж. сталь Швейцария ... Далее Ушковый хомут OETIKERУшковый хомут OETIKER 54.3-57.5 мм, ширина 9 мм, нерж. сталь Швейцария, 10 шт. 16700236 | 765 ₽ на складе |
DIN-рейка CHINT L2000 TH35-7.5 оцинк. 570002 | 528 ₽ на складе |
Искать "3575.5" в других поисковых системах: Везде-РадиоЛоцман DataSheet.ru Google
USD | 93.2918 |
EUR | 99.5609 |
